- Replies 12
- Views 3k
Mopar1973Man 4 posts
Daleb 2 posts
dave110 1 post
Bullet 1 post
Popular Days
Just about every country in the world, other than the good old USA, haha.
Actually point it the brass side of the temp sensor. Thermostat housing will most likely show cooler. It the temperature on the other side of the thermostat that counts.
Optimal temperatures... Coolant temperature: 190°F to 200°F Intake Air Temperature: 100°F to 140°F Fuel Temperature: 100°F to 140°F Coolant temperature needs to be as
Is this the normal spot for the temp gauge to run or should I try replacing the thermostat?
