- Replies 8
- Views 11k
Stanley 2 posts
Mopar1973Man 1 post
dripley 1 post
015point9 1 post
I have opposite problem. Older I get, my body parts fall apart all by themselves
I was pretty shocked than nothing I took of my truck for the head gasket swap was seized. Not surprised on the drivers side but the exhaust side bolts had never been turned other than the turbo back i
So here ya go, you can press them out. Used a 1 inch drive 2 3/8 socket and an old bushing from a machine as a push through, worked like a charm. I did have to cut the bolt end off but someone's
Anyone ever removed the inner sections of the motor mount?
I'm going to be replacing them with the poly inserts from Genos or from polybushings.com
I have engine out and mounts off of engine. I assume they are just pressed in, and I need to press out?
