Not your average vp44 question
- Replies 24
- Views 4.5k
Dieselinmyblood 8 posts
dripley 3 posts
IBMobile 3 posts
Me78569 3 posts
I have two second gens so a lot of bullet proofing gets done to both trucks. I just want to say that the G 100 ground was hidden on both mine. Hiding under a small bit of wire harness way down low in
I’m not trying to do it permanently. I meant once it’s acting up I can flip a switch to send power where it needs to be and turn the ignition off so it isolates it to only the ecm and vp44. I’m not lo
First time posting but I’ve reading and gaining from this site for quite some time . Thus the title of this post. I’m really struggling with my truck and I’ve read just as much as I possibly can. My background (just so no one is afraid to through anything complicated at me) is 10 years of diagnosing and repairing medium and heavy duty trucks and now about to reach my 5th year of being a shop manager.
Sorry this might be long winded. My 99 is a fairly new purchase and it wasn’t acting up when I got but now it’s getting terrible.
The two main issues are : when I first leave my house and start driving it will (only once or twice) loose power but it’s not the same dead pedal every one else describes. The truck doesn’t die and will rev up in response to throttle input. It’s just very low power and slow to respond. After it works that hiccup out I’m fine for a bit but eventually the truck does start dying . And yet again it’s nothing like I’ve read about. It’s a standard so with it still in gear and rolling down the highway, literally all I have to do is cycle the key and it’s rolling on full power like nothing happened. It has never not come back to life and when it happens somewhere where I do have to restart it, it fires instantly back up. Everything I’ve read says it dies completely or is incredibly difficult to restart . I’ve checked just about everything that I know of or have read about. I installed new batteries due to one of mine actually being bad. No change. Trying to be lazy and hoping it was something simple I changed the apps. No change.
The truck has never had a CEL. I even forced a CEL to make sure that part was functioning. The wait to start light functions completely normal. Sorry I’m bouncing around I just wanna to give as much info as I can .
Another thing is that while test driving it down the road to try and diagnose it with my scanner, as soon as the truck dies my scanner gets kicked out and says no communication. The scanner attempts to reconnect and if I cycle the key it reconnects and functions fine until the next time it dies. Also when running the scanner shows that the vp44 is claiming to only be getting 12.1-12.3 volts. I haven’t back probed it yet to test while running with a meter but I have unplugged the pump and checked the power and ground and it was within .01 of the batteries.
Sorry I know that’s a lot and there’s still more that Ive done but I know there are some very expienced people on here and hoping someone can help. That’s why I joined this one. Definitely a lot more info and a lot less “how do I roll coal” nonsense.
Edited by Me78569
