Drove the truck over 100miles today, hasn’t done any kind of distance in awhile.  After about 30 miles, started to feel gravelly pedals, both brake and clutch felt weird, when pressed felt gravelly under my feet.  Braking seemed a little weak too and power steering more intermittent than normal.  At about mile 40 had to brake hard compared to normal braking and the truck pulled left...  not sure where to start my chase, any thoughts?
  • Replies 119
  • Views 16.9k
    When was the last time you changed the power steering fluid? Remember Power Steering fluid need to be changed every 30k miles.
  • I got a vacuum pump rebuild from Gould. And new ps lines and a new ps pump both borgson. All three are you get at Genos Garage. There's even a video straight from gould on how to do the vacuum pump re
  • Put a cap or plug of some sort on the reservoir nipple where you took the hose off so the oil stays in the reservoir during the process. I cut a short piece of rubber line, stuffed a bolt in the end t
If time is not an issue, rebuild it yourself.
rebuild Kit is like 5$   rebuilt caliper is $30 or so.    So there is money to save and experience to have.
GL
Hag
GL
Hag
Thank you Hag?  Where do you get remans for $30? I am thinking some of the remans come with the bracket, not sure what just the brackets cost or how that cost will compare to a reman.  If the reman comes with brackets and I am going 3rd gen might make sense to buy the reman with the bracket.  Also are rebuild kits readily available?  Best places to buy these types of parts?
Edited by portlandareae28
better english :-)
I just looked on rock auto.
coated cardones are 30 bucks  and go up from there. (high core but send the core in...)
kit is really 3 something.
not sure what is needed to go gen 3.  (their calipers seem to be more expensive and show different part numbers than ours.  so if your going gen 3 get new calipers  they may be different)
new brackets for an 03 (I assume that is the 3rd gen) are about 20 each.
Hag
Hag
My understanding on everything I have read is that the third gen caliper is a little different, but not necessary, and has different size/thread for the brake line connection.  But many people have just switched the rotor, caliper bracket, and pads and kept their 2nd gen calipers in tact.
If you go with rebuilds DO NOT use Oreille's.  Did a brake job 2 weeks ago where the customer supplied the parts.  I went through 3 left calipers to find a good one.
I normally use the Centrex brand; never had a problem with them and yes they come with brackets.
I used NAPA economy pads all the way around and cleared 180k on the first batch of brak pads, then over 200k on the second batch of brake pads. Rotors lasted over 380k miles before I replaced them. The economy pads have way less metallics in the pad and dont eat up the rotors.
I will find part#'s tonight.  Thank you for the feedback!!
Thoughts on where to get that brand?  I know you have sources that I may not have access to.
This is the route I took. Easy and an excellent upgrade :thumbup2:
So it seems the banjo bolt is different if I were to go to a third gen caliper, so thinking I want everything new in there.  Will do a 2nd gen caliper, third gen bracket, pads and rotors.  I am going to tear into the rear drums too.  I have read about a wheel cylinder upgrade eons ago, is this worth the trouble?  I think it was a GM part maybe.
I kept 2nd gen calipers. I also have the larger wheel cylinders in the rear.
On 7/3/2019 at 3:13 PM, IBMobile said:
The old Volvo used this type of pump up to 1984 and the rear mounting bracket used those bolt holes.  I've had to reseal the pump reservoir due to leaks there.  There are O-rings that go between the pump and the reservoir housing that need to be replaced.  it's a very easy job to due once the pump is off the vehicle.   another time I had a pump leak because of a short hairline crack in the reservoir sheet metal at one of the bolt holes.   I think, it was about thirty years ago, I brazed that crack closed.
        The kit is cheap, $9-$14, an can be found at most parts suppliers.
762421696_8002fd941.gif.a9fb7785eb1724b6eeef979440ec4880.gif77385367_th9(2).jpg.2211a3f77878549f9abf771346e2f029.jpg
Just a heads up. NAPA does NOT sell the main reservoir seal. That reservoir seal can be replaced without removing the pump. Not hard at all. I got the store manage to order a pump and stole the seal from pump. Then like I said I removed the 2 return hoses and the one pressure hose. Unscrewed the bolts and the regulator removed the reservoir and cleaned it out. Replaced the seal and slipped the reservoir back over the new seal and assembled again.
Do you feel it was all worth it?
recall which wheel cylinders you went with?
I will look into this.  I am not sure at this point if the leak is coming from the reservoir and traveling down the lines or if it is coming out of the top of the steering box
I also went with the larger wheel cylinders, IIRC it was 1 3/16" I believe which is bigger then the 1 1/8" that was stock? It does make a difference if you don't have a load valve on it.
I think it's worth it. I replaced the wheel cylinders about 4 years ago and noticed a difference. The front brake upgrade was very noticeable.
  • 3 weeks later...
Front brakes are in, thought I was doing something wrong while trying to bleed.  But it seems the fluid was just escaping the system somewhere near the rear 1/3 of the fuel tank as it is all wet and fluid is dripping from there.....  guessing maybe a rotten/rusted line back there somewhere unless there is something I am not aware of that could be causing this?  Any help is greatly appreciated..
Behind the fuel tank seems to be a common place to lose a line due to corrosion.   I have not experienced this, but have seen other posts where it happened.
GL
Hag
Does this look like the right replacement line for plug and play?  Not sure how confident I am building my own line. I am looking for the line that runs the frame rail from the front of the truck to the rear diverter.  Sorry for the ignorance, I am beyond weak in this arena
https://www.summitracing.com/parts/mop-04683310ab?seid=srese1&gclid=CjwKCAjwkenqBRBgEiwA-bZVtqUWKKY6a8f-bMd3L_akVd4VGoi9OMrS0CBqN0V4SaTZ9xIlO_XEbBoCTnsQAvD_BwE
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = {"communitymap":{"front_markers":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_markers.js","front_showmap":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_showmap.js"}};
