- Replies 16
- Views 1.9k
Popular Days
The only thing Dripley would consider an upgrade would be a chicken hood ornament or such............
The only performance up grades I have done to mine is a 4" exhaust, different waste gate, rv 275's, AD II 165, Banks tuner, since failed, then a Comp, still on it. I did put a new set of 16 X 8 wheels
99, busted dash, sagging headliner, oil leaks....... For a minute there I almost went to look out the window and see if somebody stole my truck . I'm pretty sure the dealer can take care of your tire
Been lurking the forum forever but haven't posted much because I can usually find the answer.
Anyways, I just bought a Frankenstein 99 Dodge that's p-pumped, with a G56 transmission. It also has an S363 turbo with 70 hp injectors, and it's leveled on 35x20's.
Someone has spent a significant amount of time and money upgrading this truck, but it also came with a lot of issues. (I might add that the body and paint on the truck is 9/10, only 1 noticeable dent.)
For instance, the front end is loose as hell, but the truck came with all the parts to do a front end rebuild. The dash is busted all to hell, the AC doesn't work at all, the gauge cluster doesn't function, headliner is sagging, oil leaking from somewhere, and the interior bezels and consoles are tore up.
My question is regarding the gauge cluster, the guy I bought the truck from claimed that the current cluster is a junkyard special that worked about 8 months and then quit on him. I'm curious if some of the upgrades are compatible with the stock cluster or if there is an underlying issue with the truck such as a bad ground somewhere. I guess I'm mainly curious if I purchase a different cluster, with a G56 transmission will the cluster display the proper rpm's and speed?
On a side note, with 35" tires, can a dealership reprogram the truck for an oversized tire so the speedometer will work correctly? Or would I need to buy something aftermarket like an Edge Insight?
Sorry for the long winded post, thanks in advance.
