- Replies 55
- Views 10.3k
Leaky88 14 posts
Mopar1973Man 11 posts
dripley 10 posts
01cummins4ever 5 posts
I have run 19 to 20 psi for the past 8 years. Nothing wrong with 18 psi either.
Let us all rember that if the ecm is used to run the lift pump and that there is no factory relay to the stock lift pump. The FASS and AD both come with a wring harness with an after market relay. If
I did take note that the OP, said I suspect that things are indeed electrical issue based. It sounds like the alternator has massive blow by, or the ground cables are bad..
Hi,
Installed reman VP44 from DAP, no codes, no problems. But engine now requires excessive cranking to start when hot. It fires right off when hot.
Truck has FASS 150 that provides 20psi all day and I've always used a protected isolation relay between ECM and the FP.
In preparation for a trip last weekend, and with limited time, I modified my existing isolation relay by adding the NC relay and using the B+ from brown solenoid wire to hold FASS150 at bay during cranking. Moparman has an article on it.
No noticeable improvement was seen.
I switched to a FASS DDRP-02 I have as spare (circa 13psi) and truck fired right off. Suspect problem is too much FP from FASS 150.
But I want to retain the FP 150 for the FP it provides to VP44. (The one I just replaced.)
I have read that one can change a spring in the 150 to reduce FP. Again, I like the 20psi for the VP44 and would rather not dink with the FASS 150.
Since the FASS runs for 10 secs when key is turned on, I am entertaining getting B+ for the newly added NC Relay shown below - from another source than the solenoid, and installing a NC spring loaded switch to control the LP NC relay until engine fires. This procedure would only be done/needed when engine is hot.
Anyone see a problem with this? It seems like a harmless mod but given the problems these trucks have with AC noise etc. I need to ask.
Thanks.
Leaky
As soon as I get this done, I need to find out why I have a TC Lock/Unlock issue that magically appeared during my trip.
