Truck died while driving
- Replies 21
- Views 5.5k
dripley 7 posts
closupman 5 posts
JAG1 2 posts
BrownTown65 2 posts
Popular Days
Electrical gremlins will make you crazy if you are already not.
OK, the way your truck died is the same way mine did when the VP44 died just north of Riggins, ID almost two years ago. I suggest you do a VP44 hot wire test.
Several days ago, my truck died while cruising at 60mph. There was no warning, pops, knocks, or clunks. The rpms dropped to idle then a few seconds later dropped to zero. Truck had full power until it died. Fuel pressure is good. Only throwing the p1693 code.I believe it to be a ground issue. The truck radio lost memory after sitting overnight and turned the am radio on. I'm looking for wire diagrams or someone who has maybe had a similar issue or any ideas. Anything will help!
Edited by BrownTown65
