Truck died while driving
Several days ago, my truck died while cruising at 60mph. There was no warning, pops, knocks, or clunks. The rpms dropped to idle then a few seconds later dropped to zero. Truck had full power until it died. Fuel pressure is good. Only throwing the p1693 code.I believe it to be a ground issue. The truck radio lost memory after sitting overnight and turned the am radio on. I'm looking for wire diagrams or someone who has maybe had a similar issue or any ideas. Anything will help!
Edited by BrownTown65
  • Replies 21
  • Views 5.6k
  • Electrical gremlins will make you crazy if you are already not.
  • OK, the way your truck died is the same way mine did when the VP44 died just north of Riggins, ID almost two years ago.  I suggest you do a VP44 hot wire test.
What year second gen do you have? Did you pull the code with a code reader or just off the odometer/ key trick? There will be other hidden codes that show with the code reader and give a better clue.
Also what's the miles on it.
Man I'm surprised no one has tried to help you. Guessing like me it's the time of year. I'm barely able to keep up.
Please fill out your signature so we know what has also been done to the truck.
Welcome to the forum, BTW.
It's a 2001 with 220,000 miles on it. The truck is completely stock except for a BHAF and a straight pipe. I just cycled the key to get the code, I've been waiting for my neighbor to bring down his snap on code reader. Thanks for getting back to me!
The key trick works mostly on the 02's and some 01's. Yours is just reading one computer and the 1693 is telling you there is more in the other. The Snap on ought to do the trick. Welcome also.
Yep watch out for the 'Chicken Man' he'll peck you to death if your not doing something right. Thing is that chicken is usually right.:thumb1:
Is the engine still not starting or did it restart?
Engine still does not start. Voltage and ground are all good to the injection pump. The neighbors snap on code reader pulled out several more codes. Picture below. We were going to jump the pump to see if we could get it going but batteries were to low. Plan on connecting charger in the morning and trying again. However we could here the pump click when we connected the wires from the pump to the battery. So not sure if that means it may still be good?
Everyone thinks I'm crazy but the grid heater cables came loose on me. The ones below drivers battery. Truck would die driving down rd
Check them,Only takes a minute.
You are crazy, man :wink:
These trucks are full of surprises
Electrical gremlins will make you crazy if you are already not.:ahhh:
my truck did the same thing at 30mph no warning nothing towed it home about a month ago not throwing any codes but I don't hear the pump kick on with key am I mistaken or would that not cause a code it is a 98.5 24 v ? any suggestions as to where to look firstly?Thanks I will be following trying to learn lol
Have you put a scanner on it to check for codes?
yes I did and there were none Thank you
since I do not hear the lift pump when key is turned on is that telling me something? always heard it humm prior to this episode
a relay maybe or would that throw a code?
truck cranks just fine
Edited by closupman
Is your truck stock? Stock there will not be a relay for the lift pump. There is a relay in the PDC for the VP.  Swap it for the horn relay or any other that works and see if that helps. The prime of the lift pump at key on is ECM controlled. Does your WTS light come at key on? If its warm out it is only lit briefly so you have to watch closely.
OE style lift pump?  When my original went the truck woild not start.
Edited by dripley
yes no humm probably indicates it faulty? do they go just like that No warning ? Thanks
should I possibly check connection (plug) or is there a way to determine that it is shot?
You could pull the connector and see if you have voltage at the connector after bumping the starter. Voltage should be present for 20 seconds or so.
exactly what I was thinking just double checking thanks
