- Replies 12
- Views 3.2k
Mopar1973Man 3 posts
dripley 2 posts
JAG1 2 posts
Timburrr 2 posts
On the Stock APPS it is based on voltage in must fall below the tag voltage at least 0.1 below. On Timbo's its based on bellcrank angle, no voltage used. Just replace it with Ti
I have Timbo and exhaust and they work fine. When I was having surging issues it would disable the E brake with any surge no matter how small.
From your post I don't believe you have a DC supply problem. New batteries with a resting voltage of 12.7 is a sign of good health...I'm assuming the test was performed individually to show a resting
The root issue I am having is I am getting the APPS low voltage code. How I realized there was an issue is my BD exhaust brake intermittently will not work at low rpms (and it changes minute to minute what rpm it will cut out at, but usually around 1000 rpms). I checked codes through my Edge Insight and got the APPS low voltage code. So right now, I am leaning towards thinking it is alternator related, but my initial quick test in the parking lot at work doesn't agree with that. I'm going to break up my post into each little point, otherwise I ramble on a long confusing paragraph.
Previously, my exhaust brake acted up my batteries tested as being poor to marginal, so I replaced them and my exhaust brake acted completely normal again up until now (I believe that was last summer).
AC noise check came in at .022 VAC. I don't know if I believe this though. I had everything turned off (stereo, lights etc) but I didn't unplug the fuse to my A-pillar gauge set or my exhaust brake (but the switch was turned off so I don't think this would be an issue). Also, my multimeter is a hobbyist one: a fluke 17b+ which is an asian market unit, not a solid unit like a fluke 87, and it doesn't read true RMS so my understanding is these readings won't be true. Can this be confirmed? Do I need to get someone with a better unit to test the AC noise? Did I have enough accessories turned off?
Alternator voltage came in at 13.7-13.8 at idle. Before turning on the truck battery voltage was 12.71 (Batteries are about a year old and are high quality batteries).
Exhaust brake ties into the idle verification system and then I had to manually set the sensitivity on the controller so when I push on the accelerator the exhaust brake kicks off. I guess I should check this connection, because it could be poor I guess?
The records from the previous owner (My wife's uncle who passed away) show that the APPS was replaced around 7 years ago or so. Maybe another one bites the dust? I haven't had a chance to find it again but I think I found a detailed flow chart on here somewhere to diagnose APPS. My understanding is I can try to manually put the APPS back into its stock voltage range and the results seem mixed by doing this? Obviously if APPS is bad, purchase and put in a Timbo APPS?
Hopefully its not the PCM? I understand they are very expensive and hard to find and sometimes don't even transfer well to a different truck?
What's my next move, attempt to diagnose the APPS and/or re calibrate the voltage?
Thanks as always!
