Thermostat... just a good one
I know the good Cummins thermostat is expensive..... Maybe not
What Brand is a good reliable  thermostat . genos sells the Gates -33915
Edited by GSP7
  • Replies 46
  • Views 17.2k
  • The standard in stock Napa thermostat is Motorad for the 180 or 190. They offer a 190 Safe-T-Stat special order, it is the fail safe type. They also offer a stainless steel one, special order.
  • Anyone that works on their own vehicle knows this. My point is, oem has different specs than the aftermarket, they will fit and work. Aftermarket will usually fit and might work.
  • I don't know who the vendor is, but whoever it is they will manufacture to Cummins specs. You say the 2019 is different but without a part number it is hard to say. That t-stat looks like a 12 valve s
Most Helpful Posts
    I left the factory 190°F thermostat for a Gates 200°F and gained performance and MPG.
    Some quick guidance on the Quadzilla. You will see about 204℉ to 210℉ coolant temperature on average. The bonus is the oil temperature measured at the test port on the oil filter head, you should be f
18 minutes ago, Mopar1973Man said:
Umm... Both Cummins and the new one was dead in the box... Hmmm... But this is NOT a OEM on the left being OEM is on the right. Both are Cummins thermostats. Also people are quick to complain about something but rarely give praise for something that does work. Being I've been using NAPA I've not had one failure YET. All thermostats have worked without an issue. I will give NAPA thermostats some kudo's.
Missed that post (back to getting too many emails, and clicked the newest email link), however, did you get a replacement for the new one? Did it look the same? That looks like the wrong part, as it doesn't appear to be designed to work properly with the bypass, which would make it run cold.
It's easy to tell just from your photos it's not going to work properly.
Quick search shows other threads where your "NEW" thermostat is the wrong thermostat for the application. So that begs the question, are they mis-packaged or wrong in the parts manual. One thread was 2012 with the exact same thermostat...so it's not a "New" design.. it's the wrong thermostat.
Same issue as you, running cold... so that's not a failure of the thermostat, that's the wrong part for the application... those are 2 very different things.
I'd give NAPA praise if their stuff worked... it just never has for me.
Edited by AH64ID
stop arguing ! - geeze!
Think Ill get the Napa OE 190*  Napa # PM-1906245....
Mike what's your Napa Part # in your truck
Dont need the safety one and its a 195*- # SS1956247... It just locks open if you over heat , then is stuck
It is the right application just failed. That is the new 2019 thermostat from Cummins.
13 minutes ago, AH64ID said:
Missed that post, however, did you get a replacement for the new one?
That is the new on on the left. Dead and no good. That is for the 2002 ISB Cummins 190F thermostat.
No. The right thermostat is the previous Cummins thermostat way different. But the right part and just changed manufactures. Cummins no longer sells the previous version and changed manufactures. He even asked if he could get that same MotorRad thermostat but no longer used by Cummins. Again just because its OEM doesn't mean you get the same part.
Umm... 190F thermostat staying cold is not a failure? Doubt that, Cummins thermostat failed to open at the proper temperature period.
Point is I'm trying to get people to look at the manufacture more so than logo on the box. Being there is only a handful of manufactures of thermostats and these logos like Cummins just buy from one of these. Now if we knew who made the thermostat we could go to the company directly without the logo'ed box. Like there is Gates, Stant, etc. Who made it?
Quit arguing, and help the OP with the question , Holy Cow !
Mike, what's your Napa thermostat Part # in your truck.
Edited by GSP7
Just look at it, it's very obviously for a different application. It's not able to close the bypass, hence wrong application.
You should have enough experience and maintenance know how to realize that, and shouldn't have installed it.
It's not new.. I quickly found photos of that EXACT same thermostat from 2012. It was the wrong thermostat for the application in 2012 as well.
Not when it's the wrong thermostat....
Only thing I asking for is to look past the logo. Look at who manufacture the thermostat. Again Cummins and Mopar do not manufacture thermostats.
 375-190 (190F)
and 375-180 (180F)
SS1956247 - Safety Stant only in the 190F series.
Just called the NAPA store for the 3 numbers...
It actually is helping with your question.
Can't help you make an educated decision when you're given information on the wrong thermostat.
Multiple people have run into the issue Michael did, so it seems that there may be some messed up part numbers in the parts manual that need to be watched out. At the end of the day there still is a Cummins part available.
Edited by AH64ID
No,,,, you are just pissing all over my thread with your childish bull **** ! ...Thanks for screwing up my thread !
OP, Did you read this? Every thing I described is in the Napa link you posted. Click on all four units that fit your truck and read the specs and make a choice. The info is all there.
You wanted information on a good reliable brand of thermostat, and now that’s pissing on your thread :doh:
This is all thermostat discussion on what’s good, what’s not, and what’s correct.  It’s not even off topic at all, but feel free to react this way.
Sorry if you’re taking it as anything else, but really it is all here to help you and anyone who searches for the info in the future.
Lol...I've been in debates about important stuff like turbos, torque converters, injectors, electronics, suspension parts and fuel pumps...and I'm pretty particular about that stuff.  But never have argued over a thermostat.  It's a freakin thermostat...it either works or it doesn't.  I've had some that have stuck before after many years of use.  I don't even think twice about it...I just go buy another one and slap it in.
My last one is from Napa because I know and like the people that work there...no other reason.  If by chance I would have purchased it from a different company instead...no sleep would have been lost since.
One thing I have for sure learned here is there are differing opinions on some things. And yes down to even a t stat. No one is definitely wrong just differing opinions. I have run both the Cummins and the aftermarket with good results. How much money you spend is up to you.
  • 4 weeks later...
I've put ~25,000 miles on my Stant XACTstat 49212.  I wanted to try a 200 degree thermostat so bought one for a later-model Ram. $14 on Amazon.  Considering my truck is an automatic, it may have been a poor choice for someone who tows heavy (transmission is cooled by the engine coolant).  I run fairly light.  If I was to hook onto a man-sized load, I'd swap the thermostat to a 180 just to help cool the transmission more.  The XACTstat I have DOES have a wide swing, noticable on the gauge and with my OBDLink I can see it goes to nearly 210 sometimes - but not all the time, and conveniently, not when it's hot outside!  It goes to maybe 206 when it's hot out before it cycles open again.  These observations are from several hundred mile trips running to Oklahoma or Minnesota from Kansas City in all types of weather.
Samething my Gates 200*F thermostat did. But the drop would swing back to 180*F before it closed.
Wow, that is a wide swing. OBDLink says mine closes between 190 and 195.
That is a big swing.  My current Napa 200° opens right at 200° and kicks it back to 190°.  Never seen it outside that range after first opening.
Just goes to show NAPA thermostat is much more stable than a Brand name like Gates. Being the Gates 200°F thermostat is being crazy my NAPA 192°F is hovers at about 197°F.
I've had great results with Gates thermostats. Very little cycling in temperature. Stant on the other hand, I've had wild temperature swings.
My Stant acted like this. Never the Gates. There might be more than one model of the same brand though.
That what I'm getting at there there just so few that actually create thermostats and just name brand vs. store brand might find out are the same thermostat. Then like I uncovered Cummins thermostats are NOT produced by Cummins. Like the Gates I've got came from RockAuto.com. Where the rest of my collection comes from NAPA. At the time NAPA did n't list a 200 available anywhere in Idaho hence to just try the 200*F I had to get it from another source. I even tried Autozone and other chain stores. No 200*F thermostat available. I was of the same feeling too that Gates should of been a quality product to only be let done as well at least for me. Not like I wouldn't try again I would try another Gates as well.
