Upgrade or Trade
I have had the itch to trade up to a newer model but after talking to several owners of different brands, most say just keep what I have and sink a little money into the 2001.
2001 automatic, HY35, 4.10, 119,000 miles. Driven 10,000 miles a year and retirement coming in a couple of years.
Here is my plan so shoot holes in it.
BHAF, gated HX40 turbo, 4" exhaust, 75 HP DAP sticks, re-build transmission. I have a Edge Juice with attitude that I might add.
Opinions?
  • Replies 22
  • Views 5.6k
  • I got him about 2 years ago. Will see 500k about March of next year. I'll save both of you a seat at the bar when you get back from the moon.
  • A quadzilla and 7 x .010 injectors and a newer style turbo.  the hx40 is a OLD turbo design.  If you want to keep it on the cheap a HE351cw
  • Well, I ended up with what DAP suggested on both the turbo (S300GX-E 57-65-14) and the injectors (7X.0085) along with the Quadzilla and a Dynamic built transmission. Going to take it on a drive today.
Thanks, i'm planning to move to your state and will need to pass emissions. Will that set-up work for that?
I passed with 7 x .012's and a quad.  the tuning is key.
The edge and 75's wouldn't pass emissions.
I think I'd do quad ,7x.010 that way you can download a good tune and start somewhere solid. No idea on turbo. The hy35 can work if you turnbuckle the waste gate. But shes screaming I've seen mine hit 38psi.
Set 6 grand aside and do power driven desiel tranny or dynamic.  Might not need all the 6 but youl be close.
That's a new truck still.  I got mine at 150k it has 307k now
Racing mike to 400 I'm coming from behind
Edited by Evan
If I keep the hy35 will I still have EGT temps at redline pulling in the Rockies? I have to really keep an eye on those temps with stock settings and the HY35.
Edited by dripley
Egts will be an issue if you tune it to run hard.  You can tune it down and i would think you will be fine, but i would opt for at least a hx35
You mentioned a newer generation turbo. DAP quoted the Borg Warner s300g 57 65 14 t3 gated hx40 and 7x0.0085 vco sticks. What is considered new technology?
There is many to choose from on the website but I was telling them my use and application, that it has to pass Colorado emissions and has to pull well in the high altitudes. My place is at 9500’.
Thanks again
I personally would not go under 7 x .010's. 7 x .009's if you are really worried, but with good tuning 7 x .010's are normally the best injector choice.    gotta remember that bigger injectors don't always means higher egt and more smoke.   A larger injector with less duration will make the same power and have less heat than a smaller injector and more duration.    PROVIDED your HP goal requires a lot of duration to reach on the smaller injectors.
That turbo is MUCH newer than the hx40, about 25-30 years newer tech :)  I would choose a 12 cm housing personally, but @dieselautopower would know better.
I ran all over the rockies towing my 3 horse gooseneck with 7 x .012's and a he351ve and did not have EGT issues. It's all in the tuning.
Edited by Me78569
Does the HE31CW require modifications to work or more drop in ready?
Also is the K27 old tech? Came across a decent used one for a fair price.
K27 is a ok turbo.  It wouldnt be my first choice, but for the right price.
He351cw requires some work to put in, there are diys on the internet.
k27 can require a bit of work too.  better as drop in for 12v..... but still nothing close to the  newer billet 57mm borg s300.
K27 is slightly better than stock and not more compressor flow than a 57mm s300 (even the old style or he351).  Keep in miond also that the k27 for the dodge were modified from the factory for fitment.  I would not expect one from the car application to do well.
Yes if you are going to do custom tuning and s357 billet then go with 7x.0095 or 7x.010
How heavy are you towing?  I tow 15k on the flat rolling hills with no egt issues with 7x009 hy35 and smarty.
Before turnbuckling the waste gate egts were noticeably higer.
I'll run under 1200 out on flats running 80mph.
But get on pull and I have to drive by the gauge and pedal off temps to stay under 12.5egt.
Towing a 2horse trailer though to 8500ft is no issues  running the speed limit 65 on mtn highways with switch backs.
No issues either pulling steep grades slow on gravel mtn roads. Under 25mph. I run in 4low.
Pulling a 9000 plus pound fifth wheel. EGT gets to 1200 really quick if I dont back off.
Turnbuckle waste gate and put quad boost fooler on and I bet youl see reduced egts pulling 9000lb on your current set up.
Before turnbuckle I had to peddle off alot of grades now I can pull most but not all without peddling off egt temps.
Pulling most steeper long grades at 65mph pushing 30plus Boost at 12.5egt sustained.  Before I couldn't sustain 12.5 at all I'd be doing 50 at the top because I had to peddle back.
Turnbuckle your current set up to see if it lowers egts and raises boost. I was skeptical that it would was fairly shocked to see more boost and lower temps together.
That's with smarty and 7x009 injectors.
When if I ever upgrade my turbo I'll probably go non waste gated if possible.
Edited by Evan
May or may not hook up the Quad for a while.
Appreciate all the advice and suggestions. May be asking about tuning next.
  • 4 weeks later...
they must have changed the parameters of the test, my 01 manual always passed emissions with edge juice attitude (stock setting) and rv275's, running on 35" tires.  i did leave colorado in 2014 though
Edited by CUMMINSDIESELPWR
FWIW, I passed in NJ with 100s and a smarty.
