- Replies 24
- Views 7k
Gregturley 7 posts
Mopar1973Man 5 posts
Evan 4 posts
AH64ID 3 posts
Greg, For the racing trailer I use a nitrogen bottle. Dude that will save your life. its easier and cheaper than sketchy cords and low voltage on a compressor, or trying to run tanks back and
Nitrogen is nice. My setup works great for me im happy with it. Did a water pump on a friends service truck 7.3l f350. Used air chisel for fan clutch, 1/4 & 3/8 air ratchet for clamps and bolts, a
Ill get some tomorrow. It was kind of dark for pics today. The 380c is mounted on the driver side of the skid plate for the transfer case. The 2 444c compressors are on a bracket i made that goes betw
I finally got around to finishing my on board air system. I now have 3 5 gallon tanks and 3 Viair compressors. 2 tanks are supposed to be from some kind dump truck other is ebay. 1 compressor is a 380c and 2 are 444c, all rated at 200psi max. My pressure switch shuts off at 150psi. I can once again run air tools from the truck. Theres also a horn behind the front bumper that really comes in handy around here.
Edited by Gregturley
