- Replies 46
- Views 12.8k
Rot Box 15 posts
JAG1 10 posts
dripley 6 posts
Mopar1973Man 3 posts
Time to move out west and be my neighbor I will build you your dream shop and then you work on my trucks
Good to know on the alternators. I’ll read up on and check the ac noise as soon as I can. Hmm I wonder why they would have wired it into the central timer... Is it bad to
You're on the right track, there's a lot to learn still. WT mod, among other things are in order, just be patient and don't hurry things up. Do the important things first to make your move, then take
Hi everyone my name is Andrew and I'm brand new to the forum. I was hoping you could help me with my ECM problem.
I have no idea what caused my ECM to fail.. Is this a common issue? Do I just replace it and cross my fingers or do I need to investigate further? The truck ran just fine until I pulled in my driveway (luckily) and it died. I had it checked out and was told the microprocessor fried and the ECM is deemed unrepairable..
Since I can't buy a new one (discontinued) do I buy a used one with no warrantee or do I get a reman unit? If reman who do you recommend? I've called a handful of remans companies and every place seems very shady with poor online reviews. I'm moving my family back to Utah from Florida and I need this truck to get us there safely. The thought of plugging in a new ECM and having it fail at any time with a big trailer in tow is really bothering me. Any advise or suggestions would be greatly appreciated. Thank you for your time,
Andrew
edit: Also my ECM looks to have been a reman anyway.. not sure if that matters but here’s a pic.
Edited by Rot Box
