New Tires Cause constant Yaw Motion?
- Replies 8
- Views 2.1k
Mopar1973Man 2 posts
JAG1 2 posts
98whitelightnin 1 post
NIsaacs 1 post
Popular Days
Last couple sets of new tires I have purchased have been squirly for the first 1000 miles or so but they werent michelins.
Thanks Dieselfuture, yes they are defenders made in the U.S.A. Imagine that! I think I better take a second look at the front end linkages too while the wife does the wheel wiggle for me.
Caster angles could possibly affect the thrust angle of the truck slightly too. Might tire checking tire pressure and maybe do a tire rotation.
I carry a slide in camper for a long time. How can two New E rated Michelins on the rear cause this almost constant yaw motion..... oversteer condition? Never ever happened before. The tire dealer did show me one rim bent about 1/8th of an inch on the spin balance. Would that be it? Front end is tight as a rock, but its squirrely to drive. Tires are the most expensive Michelins you can buy same as on front.
TIA
