Looking for Staff Members
I have a 2002 dodge 3500 5 speed, i will list the mods below. After installing these mods last weekend I have noticed my truck sounds like a 6.0 powerstroke at high rpm it makes a popping sound almost like a back fire. If anyone has any info on this please let me know.
150 lift pump
quadzilla V2
DAP 175
new so vp pump
arp studs
manton 104 valve spring
pusher intake horn
s&b intake
billet tappet cover with breather
  • Replies 22
  • Views 7.3k
  • Sounds like too much timing.  What tine are you running on the quad?
  • Grayman1995
    Grayman1995
    First thing tomorrow I will get some data logs and videos of it. Happy thanksgiving to all.
I’m running the stock tune that came on the quad and I just turned it to level 7.
Can you get a vid of the noise
My mind goes to fuel.
Is this popping under load?
What do you consider high rpm I feel over 2200 is high but find many people run the cummins to alot higher rpms than I do.
Is the truck building boost easily?
Those are big injectors, is the quad wire tapped? That's alot of fuel I wonder if it's over fueled
Have you played with any other tunes? Timing, turn off wire tap, stock tune compared to quad tunes,
I would try a tune that is geared to bigger injectors.
Any white smoke on popping?
if you could datalog the issue and point out the rows we can give you a better idea.
Could you tell me where to start with the tune sir? I’m trying to figure all this out I’m new to the tuner.
I would also recheck your valve lash, maybe some valves aren't closing all the way.
It runs good until I get into the hot tunes that add timing.
Backfire in a Cummins is usually late timing ( retarded timing for fuel amount ). The more fuel one has the more timing you need to burn said fuel. Fuel is burning after cyl & may be burning even after turbo.
all tunes add timing above lvl 2
does it pop on level 3?
check out our tune library for starter tunes
https://mopar1973man.com/files/category/22-quadzilla-standard-tunes/
Check out the tuning article for tuning info
Which one do I need?
I’m trying to figure out how to adjust the tune correctly.
If you want to figure out how to adjst hte tune please read the in depth tuning article.
as to what tune you should run, I can't answer that.  Any of the "mid" injector tunes should be a good starting point, but each of them is built with a different purpose.
I just bought the tune for mid injectors, anything above level 2 makes it backfire. So I’m stumped on what to do.
Heavy throttle? Light throttle? High rpm? Low rpm? Inside the Iquad app, assuming you are using Android, what is the date code on the far-right selectable gauge?
Heavy throttle around 2300rpm it starts. And I’m using iOS. I will get a video of it here soon. And I will data log it.
we can help more when we see a datalog.
White smoke or no smoke?
iQuad-2019-11-29-01.38.16.csv
I uploaded it sir
I uploaded videos. And data logs
I think it's the spikes on the front wheels cutting the air wheeeerd .
Damn nice truck.
It doesnt seem to smoke much under throttle considering the 175 injector plus wire tap and stock turbo
Edited by Evan
