2002 Dodge Ram 3500 dead pedal
- Replies 11
- Views 2.2k
Rhanna23 3 posts
dripley 2 posts
JAG1 2 posts
Tractorman 1 post
Check for codes using the ignition switch. Turn ignition switch on and off three times. Third time "on", leave "on" and read codes in the odometer. PCM first, then followed by ECM. - Jo
Any particular reason you dont think some of them are right? From reading the codes I would start with the batteries, charging system and grounds. Low voltage to the system will create all
All of the above
I have a 2002 dodge 3500 24 valve Cummins 5 speed manual, got in it the other day to move it and it fires right up but noticed when I put it into first gear I have no throttle but idle, could this be a apps faulty ?
