- Replies 8
- Views 3.2k
98whitelightnin 1 post
CUMMINSDIESELPWR 1 post
015point9 1 post
Doubletrouble 1 post
Popular Days
I never had luck spinning the tires, get drums turned or new ones and set shoes to were you have a little difficulty getting drum over the shoes has worked for me.
I jack up the rear of the truck with the front tires blocked and the trans in N. Now with the rubber plugs out and a small flat screw driver, start spinning the tires with your hands until you get the
I always adjust them out as tight as l can then back them off
so long ago i replaced the shoes on the rear drums. but for the life of me i just never got them set correctly and they never really held the truck (i always park in gear)
ive tried looking and cant find a comprehensive procedure for this so does anyone have a proper drum brake procedure to get them properly adjusted, i know how to replace them and such, just getting the adjusters set correctly then adjust the cable to the pedal (i already messed with it long ago)
i will be getting new shoes and doing it over again correctly this time.
thanks
Edited by CUMMINSDIESELPWR
