Isspro fuel pressure gauge
I have an Isspro 0-40psi gauge that works perfect. Only removed because it didn't match my other gauges. Used for about 10 months. If you need it give me a fair offer.
  • Replies 19
  • Views 4.2k
  • I do like my Fuel Boss
  • Doubletrouble
    Doubletrouble
    If I were back to work I'd throw out an offer. Been laid off for over a week now, hoping to get called back soon. I'll check back when I do to see if you still have it.
  • Doubletrouble
    Doubletrouble
    Yes it is. Union job to so there is a level of security in a sense as well. I'll just ride it out and see what happens. Unemployment will get me through for the time being.
Still running my old AirDog and ISSPro EV2 gauges. Then on top I've got the fuel pressure gauge programmed for 13 PSI warning light. Very attention grabbing.
They are nice gauges but i have autometer cobalts that i pulled out of my gasser. I think the Cobalt gauges are easier to see day and night plus i dont care for green lighting.
Edited by Gregturley
Mine have white lights in them. The gauge is the same except with a black face. But I do have little green covers to put on the bulbs to turn them green. They came from ISSPRO.
Roger that!
Bit of a difference @dripley most likely has a EV1 series. I'm running the EV2 series gauge. The panel light is USB programmable in the gauge plus the RED warning light is programmable for any range on the gauge. You can also USB program the needle movement speed.
Is your company seeing a slow down in business?
I wouldn't wait for them to call you back..... I'd be out looking for a job. It often meant that I usually found a better job..... closer to home better work conditions etc.
Definitely EV1's with incandescent bulbs.
JAG1,
 I don't want to jack the thread so I'll be quick. I drive a car hauler for a living, automotive industry is up and down with certain times of year. All in all the job/pay and benefits to me are worth waiting for. They project a 2-4 week lay off tops. That's what I'm hoping for. Fingers crossed! I really do like the job, hate to jump ship.
I've been hanging out here quite frequently, just reading and learning about my truck and what others are doing. Very interesting to me and a great bunch of people here.
Thank you. I was original just my notebook of answers as time went on it kept growing. The membership pool is what created the standards not me. Like myself I'm long haul as well doing at least 1,200 miles a week. I'm right around 500 HP and getting just about 19 to 20 MPG all winter long. As the odometer says 407k miles the last time I looked.
My designs if you follow... I'm more built around longevity and reliability than performance. Hence why the smaller tires and good high marks for part life. My high mark is 27.2 MPG most of the parts on the truck last quite a long time like brakes at 180k to 200k.
Moper1973man,
 That's basically where I want to go with my truck. Longevity and reliability. If I pick up some extra horse power and economy along the way so be it. Will be staying with the stock tire size and don't really use my truck to its full potential. Just wanted a long lasting platform hence the Cummins
Go down. 265's on 3.55 tend to wear front suspension more. 235's I ran for many years really did extend the brakes and way better traction. Now dropping down to 245/75 R16 on the truck changes the final gearing to 3.69:1 to the ground producing more torque to the ground. This little mod just allows more power out to the ground, and reduced drive line stress.  Yeah, I know I've managed to snap 5th gear off at 80 MPH. But that gear had over 350k miles on it... Metal fatigue...
There is all kinds of stuff you can do without going up in huge HP injectors and twin turbos...
2 hours ago, Doubletrouble said:
JAG1,
Yeah thats a good job. I can understand wanting to stay with that one.
