Should i buy a 2nd hx35?
Found a 2nd hx35 that needs rebuilt. $50 + $30 shipping. Just bought a supposedly 50k zero shaft play hx35 but haven't received it yet. Would it be worth getting the 2nd one?
  • Replies 13
  • Views 2.2k
  • Somethings got to give. I'm done spending money for awhile. I'll research this turbo thing and have another project for the future. I'm going to put the 1st hx i ordered on when the rain stops and lea
  • FYI my HX35 went 853K before I rebuilt it. Now has 42K so it's proved itself. 50K is nothing.
  • Rebuilding a Turbo isn't  hard
Never rebuilt a turbo but it may be time too. Where is a good place to get a kit?
Just paid for turbo number 2. What about the aftermarket wheels? Anyone have any recommendations?
ebay and amazon both have rebuild kits. I just rebuilt a 351ve and hopefully will see how it turned out in another couple months.
Somethings got to give. I'm done spending money for awhile. I'll research this turbo thing and have another project for the future. I'm going to put the 1st hx i ordered on when the rain stops and leave it be for awhile.
Edited by Blueox01
50k is pretty low if thats what it really is. I'm wanting to replace my hy35 and have many carefree miles. The 2nd one was cheap enough i figured might as well get it and learn something.
I was more referring to aftermarket wheels and find out more info about hx35 upgrades
If I can find one cheap enough I’m contemplating making an Hx35 hybrid like Moparman has. Want to keep my exhaust brake
Not always a good idea unless you get right wheel and housing and you can only go so big without changing the exhaust impeller. Not sure if it's worth the hassle unless parts are cheap or like you said Mike got one used from member and rebuilt it for $50 DAP sells holset kits.
Thats the kind of info I'd be looking for. Id also have it balanced if i made any major changes to it.
The turbo in need of a rebuild showed up today. Has a little more than "some" shaft play. Looks like the compressor wheel has some damage, can't tell about the hot side haven't got it apart yet. That might happen later in the week. So much for a $50 kit.
50k turbo supposed to be here Friday. Hope its as advertised.
