 I have a 2001 3500 dually 4x4 quad cab long bed, stock tire size, nv4500 5 speed with 3:55 gears. What is the average fuel milage expected from these trucks? The only "mods" done that I know of are a FASS ddrp pump in factory location and the exhaust has been replaced but nothing crazy. I measured the tailpipe it's 4" but have not measured the rest under the truck yet. So to my knowledge it's pretty bone stock with 141k on the clock.
 Last I checked I was at about 15mpg. Mainly to and from work, about a 20 Mile drive, about 5 of that is considered city the rest is state route 60mph or highway about 65mph.
 Just curious if I'm around the norm for what I have. Thanks.
  • Replies 95
  • Views 12.2k
  • I think a lot of these jobber sensors may not have the correct gap between the sensor and tone wheel. Also explains why it changes with temperature, as things expand and contract. I experienced this w
  • If you just want a small bump in power the RV275'S are great. But if you think you will get bit by the power bug get the 7 x .010's and a a Quad and you can have the stock and power together. The powe
  • I disagree. Stock Turbo and almost any injector, even 250's could run cool if tuned right with the Quad. It would be somewhat pointless, but could be safe if one tunes it safe and is waiting for a big
  • 3 weeks later...
@Mopar1973man
 I wanted to revisit this real quick. I was wondering what you thought of the data reported by the scanner at idle. (See pics above)
 Tried to tag you in this post but failed, hope ya see it. Lol
Edited by Doubletrouble
Engine load is at 0% and Idle speed is too high Injectors are shot.
TP% should show ZERO at true idle because Idle validation switch in the APPS should flipped over and trigger the idle software. This typically displays ZERO% for TPS position.
That's what I was afraid of.
 I'll have to save up some injector money. Should I go with a stock replacement or would slightly larger injectors benefit a stock engine, say like the rv275's for example? Or any other recommendations?
You would like the RV275's.  They are a nice litlle bump in power for a stock truck and you might pick up a small mpg bump out of them. I got about 1 mpg out of mine. A brand new set is about $400 or a bit less.
 Sweet, sounds like it may be the way to go for now. Not planning on big power adders as of yet but if I can improve what I do have I'm all for it.
 Those I believe are a +40 injector? Would that be the largest to install without a tuner of any kind? Any pros/cons to going maybe slightly bigger? Just curious.
49 minutes ago, 98whitelightnin said:
I would go 7x.010 or your just wasting money.
How smokey on a stock truck?
I don’t remember them being a smoke show or anything. Tuning would obviously be best but they should be fine. I hate to advise someone to get such small injectors and wish they’d gone bigger. I did the same thing when I first started but no one told me any different because I hadn’t discovered forums and didn’t k ow anyone else that had swapped injectors. I put three different sets in my first 98, starting small ending with 7x.010. A 7x.009 or .095 would probably be ok too, those are basically what I run on my 12v in a 5x.012
Mine can be smokey with the Comp. Not bad on the RV275'S but I stuck 50's in and smoke doubled for not much more power.
It is all relative to what you want I guess.
 @Mopar1973Man says I need to replace injectors, I would like to upgrade whenever I can. I don't want to smoke like an old freight train but a little won't bother me. I mostly drive empty, I will tow our camper a few times a year (about 7000 lbs). No plans on a tuner as of yet, in the future......maybe.
 The rv275's are a slight upgrade over stock, the 7x.010 flow more above those I take it.
 Will the 7x.010 injector have any other affects like excess soot in the cylinders or anything like that?
 Will I need to increase boost somehow to accommodate them? If so, what would be the best rout to do so?
 I just trying to get a "plan" in my head so I know where to start and move forward in steps.
 I am new to diesel mods and trying to learn with out making costly mistakes in the process. I will be relying on the advise I get here.
 Thanks for being patient with a newbie. Lol
If you just want a small bump in power the RV275'S are great. But if you think you will get bit by the power bug get the 7 x .010's and a a Quad and you can have the stock and power together. The power bug can be highly infectious. I do miss level 4 and 5 on my Comp while the pump remains untapped for warranty reasons.
Quadzilla and the 150 HP Injectors (7 x 0.010) @ 320 bar is bit smokey clean without a tuner. With the Quadzilla and my tunes I can roll completely smoke free on Level 3, but haze to light smoke with full wire tap, exhaust and tires. :burnout:
 I have been looking around at injectors just seeing what's out there. I saw on DAP they have a new Bosch injector 7x.010 listed as a 175hp injector. Is that the correct one? If so, will this be a 175hp increase on install or will a tuner be needed to see this increase in full? If a tuner is needed, what could I expect without one for the time being? Smokey? Any hard cold start issues?
 Just more curious newbie questions.
Basically without a tuner the timing will be off and the exhaust gets smokey. ECM is tune rather on the retarded side. Bigger injectors require more timing to be efficient. I'm running 7 x 0.010 injectors popped at 320 bar now with a Quadzilla Adrenaline and it completely smoke free reaching 21 MPG with the tuner. With wire tap I'm tuned for just a haze and it pulling serious power, enough to spin the tires on dry asphalt.
Without the tuner its very smokey. This is again because the stock ECM is tuned for stock injectors and timing is retarded pretty deeply after 20% engine load.
Starting I've been down to -20*F no issue.
 Is it safe to assume then that the EGT's would climb if using those injectors without a tune?
 Also, would there be an " in between " injector that would be above a rv275 that wouldn't require a tune?
 How long will the present injectors be "ok" until replaced?
 Sorry for all the questions, just trying to learn. Been driving gassers forever other than the semi's for work.
Empty driving not really. Towing most likely. The retarded timing was though to reduce cylinder pressures. Which it will but the cruising timing will be too low to be efficient which when you missing efficiency typically the result is added heat somewhere. Hence why the start of the power craze everyone have smoke rolling. Quadzilla is the only tuner right now with adjustable timing and producing about 180 HP.
Smarty Touch could too but at a cost of $1,800 for the full programming package and the tuner only produces 60 HP on our trucks, on CR Engine is 210 HP tuner. Basically over glorified Smarty S-03.
Only stock or RV275 injectors. This are both stock Cummins ISB and Cummins ISB motorhome series injectors.
How much engine load at idle? This will tell you. Typically injectors are done by 100k miles. Engine load will drop to zero which is the deepest the ECM can cut fuel. After this point the idle will start to rise. Injectors are failing at low (like 1 or 2%) to zero engine load.
 I think then I'll stick with the rv275's. It'll be a little bit before I can get them but as soon as I can.
 Looking at DAP they have rebuilt rv275's with good used nozzles for $225 plus a core charge.
 Do these need to be popped at a certain pressure or is what they set them at good?
 With they set the pop pres. at my request?
