 I have a 2001 3500 dually 4x4 quad cab long bed, stock tire size, nv4500 5 speed with 3:55 gears. What is the average fuel milage expected from these trucks? The only "mods" done that I know of are a FASS ddrp pump in factory location and the exhaust has been replaced but nothing crazy. I measured the tailpipe it's 4" but have not measured the rest under the truck yet. So to my knowledge it's pretty bone stock with 141k on the clock.
 Last I checked I was at about 15mpg. Mainly to and from work, about a 20 Mile drive, about 5 of that is considered city the rest is state route 60mph or highway about 65mph.
 Just curious if I'm around the norm for what I have. Thanks.
  • Replies 95
  • Views 10.8k
  • I think a lot of these jobber sensors may not have the correct gap between the sensor and tone wheel. Also explains why it changes with temperature, as things expand and contract. I experienced this w
  • If you just want a small bump in power the RV275'S are great. But if you think you will get bit by the power bug get the 7 x .010's and a a Quad and you can have the stock and power together. The powe
  • I disagree. Stock Turbo and almost any injector, even 250's could run cool if tuned right with the Quad. It would be somewhat pointless, but could be safe if one tunes it safe and is waiting for a big
Bosch RV275 are already popped and test by Bosch there is no customizing an RV275 other than that you lose the warranty. Too small of a injector to add pop pressure. Need to get above 100 HP to start thinking about adding pop pressure.
7 x 0.010 you can safely add +10 bar no problem.
Still be better off with a tuner though.
Unfortunately I won't be able to do a tuner this year, I have to many other things that need attention and money. Lol
I'll have the truck along time so in the future it will probably come to be.
The new are set by Bosch. The rebuilt DAP sets the pop pressure. I have set of the rebuilt and they me told they set them at 310 bar.
Edited by dripley
My mind says these trucks running stock turbos a quad and 150s are all running hot towing.  Regardless of tune.
Stock turbo and factory tune will also run hot but is easily peddled off.
I'd get 150s turbo then tuner in that order.
Drive by temp gauge religiously until turbo is upgraded.
 I would like to go bigger than the rv275's but in reality I don't know how soon I would spring for the tuner ($700 is a big investment, I might be a little on the cheap skate side) or bigger turbo. Then at what point do you have to think about head studs and such? I would like a bit more power but don't want to sacrifice reliability or over complicate things.
4 hours ago, Doubletrouble said:
or bigger turbo.
No turbo needed for RV275 or +50 HP. No exhaust needed either. I ran 3" exhaust for over 275k miles. No EGTs issues for daily driver.
+50 HP injectors last I checked at DAP are cheaper than RV275's.
When boost exceeds 45 PSI. You'll need at least a 7 x 0.010 injectors. Even back with the +75 HP injectors barely made 40 PSI of boost where the 7 x 0.010 injectors are 47 to 48 PSI of boost roughly. Stock HX35 turbo is good for at least 35 PSI of boost.
Call DAP DFI industrial maybe even Blue Chip.
Get they're ideas . I feel were all biased here.
I'd look at 75s as stock replacement
Good choice for injector too. Works with all stock stuff pretty good except needs to tuner to control smoke.
DAP, Industrial Injection, DFI are all good. Might call a local diesel shop for there opinion too.
I didnt feel my 100s where to smokey with factory tune.:) but I dont drive with much throttle pedal unless I'm towing
Depends on the state and local laws.
Like here around home I'm fine with black smoke. Local law enforcement isn't going to pull you over for a smoke like here in Adams County or Idaho County. Now same state and just go into Boise now that a different story this can get you pulled over pretty quickly. Ada Country and Canyon County both have smog regulations and do enforce them. Being most of my travel is highway speed and passing on two lane roads I have to consider WOT as a level of smoke too.
Smoke amount depends on the injectors. Like my RV275's with out the Edge Comp could be a bit smokey at times. +50 HP injectors from Vulcan Performance was popped to 305 bar and were very smokey without the Edge Comp. +75 HP on the Quadzilla of course the Quadzilla tunes that out good, stock ECM tune was very smokey again popped at 305 bar. Now my 150 HP injectors popped at 320 bar are cleaner than my +75 HP injectors. Bigger nozzles, but higher pop pressure really does clean it up a bunch.
I live and work in ada county though I'm registered in Elmore county.
I think I smke more than you but havent been pulled over.
Getting 15k moving is when I put on a smoke show. Empty I'm just a good haze unless I stand on then  roll some black wich isnt very often
I disagree. Stock Turbo and almost any injector, even 250's could run cool if tuned right with the Quad. It would be somewhat pointless, but could be safe if one tunes it safe and is waiting for a bigger turbo or compounds.
True. Stock turbo (54/60/12) and 150 HP injectors can be made to run with the Quadzilla. I've done it. Then upgraded to the Hybrid  (60/60/12) which mildly reduced EGT's and gave a bit more power. I was still towing my 8,000 pound 31 foot RV on the stock turbo.
You have said this many times without any real experience beyond the S03. In the nicest way possible your mind is wrong, you need to drive a truck with a proper tune.  7 x .010's and a stock turbo with proper tuning is nice to drive.
moving from 7 x .009's to 7 x .012's my EGT's did not increase with Injector size, EGT's were a result of tuning.    Same turbo more than double the fuel and egt's did not change after tuning.
I have posted these before, but the proof is in the pudding.
0-60 %50 throttle towing my old steel gooseneck horse trailer.
Lugdown locked TC od uphill high throttle - WOT with the same trailer.  Note that speed and RPM are dropping, but throttle was held high.  Next note EGT's  no out of control.  I pretty much forced the truck into the worst possible situtation and prevented downshift to see what would happen.
Lugged snap WOT passing situtation %100 throttle  50-70 mph
So again EGT's are a result of tuning, not injectors ASSUMING the injectors are built to cummins spec.
12 hours ago, Doubletrouble said:
 I have to ask:
 What are the numbers that you use when referring to the turbo? i.e. 54/60/12
Size of the turbo parts...
Compressor wheel in mm / Turbine wheel in mm / Exhaust housing in cm2
Stock HX35 is 54mm / 60mm / 12cm2 or for short 54/60/12
I'd love to drive a quad truck with a proper tune with injectors and stock turbo with 15k behind it so I can gain the experience.
If I dont peddle off I'll buy you a coke
Just do it.
I've done plenty of heavy hauls with my truck from firewood, tractors, backhoes, hay, etc. I plan on being hitched up to my RV in the next week. I typically cross the scale with the RV somewhere at 17,000 GCW pounds loaded. The hay haul was about 18,000 just the trailer. Quadzilla did really good for the early beta testing days.
Injectors first.
Guess I'll have to run up there with the backhoe. You will gross 31500.  Kidding been a long time since I I towed that much behind a pickup.
It's just hard to believe that 150s stock turbo that a quad can magically make it run cool. Ofcourse a empty truck has no concern.
Fuel = heat theres enough fuel there with 150s and factory tune to see high egts while towing.  Does quad pull fuel and timing to reduce this heat.  Or certain throttle parameters
Gearing, my man, gearing... I'm not running oversized tires but 245's stock size. This compared to 265's is going to drop me from 3.55 to 3.69. This translates to easier launching heavy loads. cooler EGT's, and less fuel used to keep rolling. Like my other post it reduces the engine load (applied fuel). Lower the engine load less fuel, means less heat!. I've ran my HX35W for quite a long time hauling with both Edge Comp and Quadzilla now. Like the last 3 years I've ran the HX35/40 hybrid.
Yes. You can pull fuel below rat as well. Any fuel number below 100% is going to cut that much off.
ECM-> requesting 75% fuel (3,071) -> Quadzilla 90% (2,763) -> 67% fuel given.
The numbers are the fuel command numbers Quadzilla feeds to the VP44. It a scale of 0 to 4,095. Or engine load 0 to 100%.
