- Replies 17
- Views 6.8k
Collinst15 6 posts
Evan 3 posts
kzimmer 2 posts
Great work! 2 posts
Better hope she doesn’t get to ride in a 2019, you might be trading both your 2nd gens in. at least mine was that way, but I had to remind her that we still had to eat and pay the mortgage
When you say no first gear, is it slipping in first? Starting in second? Starting in third? Either way, here's a snip from another site, which either comes from the FSM or ATSG manual.
Was the accumulator spring broken? Is tv operating normally cable not broken? Does it down shift at all on its own when coasting to a stop with or ith out brake input?
Hello all,
This year is not a good year for my 24v. I have been having some issues with the 47re in the truck. It would sometimes seem like it would skip 1st gear so this past weekend I changed out the Gov sensor and transducer, but now I have no 1st gear even if shifted manually. I adjusted both bands to spec and trans seems to just glide into other gears. The atf was dark and had dark sludge on the magnet, but nothing excessive. Have the clutches burnt out? I'm at the point I may trade it in on a 2008 Ram 2500 with 6.7 and g56..
What do you guys think?
Tim
Edited by Collinst15
