Ball joint part numbers
- Replies 8
- Views 3.2k
CUMMINSDIESELPWR 1 post
wil440 1 post
Ronniemx3 1 post
The_Jackale 1 post
We have several threads on this thru the years. I get headache every time it comes up. Crapshoot is an accurate description. I am running Moog on mine with 250k on them now. Just lost the tie rod end
i messed up two balljoint press tools doing mine, i even used heat and dry ice.... still boogered threads on the presses (cheap advance auto rentals) expect a days work to do them on your
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/
Hi I'm going through the front end on my 99 24v 4x4, I want to replace the hub ball joints.
Ball joints on my truck seem to be in the hub/carrier rather than the axle. Has anyone got the part numbers for the correct ones? And what brands do you guys recommend.
I live over seas and dont want stuff that's going to fail early, also being in the UK returning the wrong parts is costly ??
Thanks
