Pellet stove recommendations
- Replies 12
- Views 3.5k
015point9 3 posts
Mopar1973Man 2 posts
War Eagle 2 posts
JAG1 2 posts
I have 2 Harman Pellet stoves that I have installed about 13 years ago. They will heat the house completely and keep it at what ever temp you want. The main heating system for the house is water sou
I looked at many brands for both sizing capacity (BTU output) burn efficiency, auto start capability, fuel burn rate, stove style and cost. There were lots of brands that have auto start f
I've always sided with just normal wood stove. Pellet stoves tend to eat a lot of power with the blower running all the time. Then all the power for the auger and pellet feed. Then if the power does g
Brother in law used to live in cold country, northern Idaho, almost to Canadaian border (now passed away). He had a pellet stove that feed pellets into an augar type tube that was connected to a wound up spring device. As the spring unwound, the pellets dropped into fire box. No electricity needed, or in my case looking for something when our elect goes out.
Any manufactures you would. recommended?
