Want to drop an inch off my 2 in. level kit.....
Is there a simple way to reduce the two inch lift in the front of my truck to one inch lift? Or should I do it again with one inch spacers? Thanks for any thoughts. I have the adjustable trac bar and saved the factory end links so it's easy that way anyhow.
  • Replies 41
  • Views 7.9k
  • This is the only wrench a carpenter needs.
  • Well, I had it done, both sides for a total of 85 dollars. It's nice since the new spacers are rubber so the half inch factory rubber spring bushing did not have to be used. It's cool, I have more roo
  • Dieselfuture
    Dieselfuture
    you reminded all of us why we try to do everything by our selves.    After all them chicken jokes you better    Something like that, I never had to disconnect my sway bar links
1 hour ago, JAG1 said:
Mike, no one but no one has a wood stove door big enough to fit those pieces you got in that truck! What are you thinkin? :)
Guess you never heard of Paul Bunyon, huh?:whistle2:
Jag , sorry couldn't remember and its not in your sig.
The shop is not lying to you.
The 4wd is stupid easy if you have a chassis lift.
disconnect shock. disconnect sway bar.
Raise frame to droop front axle, zip out 3 bolts on upper spring mount.  spring is out.
they won't even pull the springs out on yours.  they will just take the buffers out.
The worst they would want to fix is sway bar mounts or shock bushings.
Hag
Edited by Haggar
If you need more work on the front end you can wait till April when I get there.
I'll watch and drink coffee.  1979312587_animated-smileys-drinking-0511.gif.b82f0d32057dab736e087a9bf15396ae.gif
You are able to accomplish that better than anyone I've ever known... your the man :thumb1:
Actually I understand that very well as there is something very enjoyable about that. I think Dripley may know and understand why that is.
Well, I had it done, both sides for a total of 85 dollars. It's nice since the new spacers are rubber so the half inch factory rubber spring bushing did not have to be used. It's cool, I have more room to air up more if I like and the truck won't squat like a chicken over eggs. Sorry Dripley.
Anyhow I like it much better, seems to handle better and the truck doesn't look like its trying to pull a wheelie in front. Thanks to all you guys your all welcome to come and sit watch me work and drink all the coffee :thumb1:
Just a little note one place wanted 600, the next place wanted 300 and the last place I called wanted 85 and he was done in an hour like he said. They were nice people there.
I have the two inch level kit for sale if interested. They are solid steel. not the hollow ones. Longer sway bar end links go with it.
Hahahahaha...also sorry @dripley.
Nice...glad it came out well! :thumbup2:
4 minutes ago, dripley said:
Me thinks me buddy @JAG1 is addicted to chickens.
Southern fried chicken, chicken fried steak is the best.
Need to adjust the track bar a bit. Just sprayed with some oil will try later. It's only offset a quarter inch but when loaded it will grow worse so trying to center it. Man what a pain..
Who are they so other members in the area can use them.
They are up near Portland Raceway, called Central 4 Wheel Drive. They are in the same building as Baxter's Auto Parts. 503 283-1291. I even had coffee left when I got home. Hahaha.
Can't beat that kind of price and service
Hopefuly you're not missing any nuts
Yeah, would be terrible if they stole your nuts..................... Especially if you didn't notice.
Even the shocks are right side up unlike the nuts on this forum :lol: Now how did we go from two inch spring spacers to fried chicken balls?:think:
Your terrible Dave110...:lol3:
It aint easy being me, but I try hard.
At 68 gravity takes it's toll like everything's 5 times heavier, but you guys lighten it up for me. :thumb1:
$85 sounds right for that job...with a 2-post lift.  No more than an hour...lift makes it fast and easy.
Keep your drawers tight, we're not helping to keep your nuts in the basket.
Thanks Bullet at my age I need fast and easy.
You and Dave110 are obsessed :lol:
I have to get a bigger wrench for my track bar. Nice big crescent wrench :spend:
