Can't boost above 22psi with the wastegate plugged
- Replies 14
- Views 3.8k
Mopar1973Man 3 posts
Rather Be Wheeling 3 posts
dripley 2 posts
kzimmer 2 posts
Give you a clue. Normally I can hit 47 PSI. I pulled the wastegate hose off and left it open, then pulled 1 bolt out of the manifold. It whistles very loud but I was still hitting 43 PSI o
@Rather Be Wheeling can you post the specs/mods your truck has? What injectors, what turbo, auto or manual, year, etc. Also if you can, it's helpful to put this information in your signature so you do
Long time reader first time poster. This is most likely my last resort since I've searched all I could to find out the issue. My truck has never boosted correctly since I got it. I'm running a V2 tune from on this forum and it's been great until I get to 22psi. Then that's all she's got. My boost gauge just sits there. And that's with my foot to the floor. Clamped the wastegate line and still nothing. Any insight would be greatly appreciated. Thank you!
Edited by Rather Be Wheeling
