Fuel system questions
- Replies 16
- Views 3.3k
wil440 6 posts
Mopar1973Man 3 posts
JAG1 3 posts
dripley 2 posts
Popular Days
no arguing... lifes too short for that... there is more than electric to choose from is all and assassin was cheaper than a decent Fass anyways
interjected or added to I have a Cat canister prefilter before the assassin as I really didn't like the thought of no filtration before the pump not sure what micron but Cat use it before their
I dont think the mechanical is any cheaper when you add extra filtration that the electric pumps come with though I have not priced compared them in a while. To the OP, i would try to do t
I want to begin to upgrade my fuel system, truck is stock for the most part (see sig) but does have a FASS ddrp lift pump. What I'd like to do is relocate the pump to the frame near the tank with a relocation kit and run a big line kit from the tank to pump, pump to filter housing and then filter to VP44. Can I do this in steps? Such as filter to VP first, then relocate pump and run the rest of the big lines at that time? Or should I just accumulate the parts and do it all at once? Will I also need a draw straw with this setup? Also, will the larger lines decrease pressure? I'm not a fluid expert but I would think larger lines would increase volume but possibly lower overall pressure?
I would go to a better FASS setup but that expense is not in the budget at this point, I have other things on the truck to do as well to set it up for towing our camper. I do want to address the fuel system this year though. It will all be a work in progress over a period of time.
Thanks for any input.
