Abs nightmare
So I've had my abs light on for over a year now. I replaced the front wheel sensors, the rear speed sensor and the wheel bearings.
I gave up and took it to the dealer and they determined that the module was bad, so I sent it into sia electronics to have it repaired. Installed the rebuilt module in the truck and I still have the light.
I'm too deep to give up now but what other variable could be causing this?
  • Replies 22
  • Views 6.4k
  • Update: After a few days with the repaired abs module, the light went away. One more thing off the list
    DRBIII tool is about the only thing I know of that reads the ABS codes. Even my 500 dollar Innova Code reader with both SRS and ABS can't read the Dodge ABS.
Mine was on for a few months. Replaced the front bearings and the rear sensor and the lights stayed on like yours. Then about 2 months later the lights went off. That was couple years ago and the brakes have worked fine sine. But it is still a mystery to me as to what fixed it.
Bulb burnt out :poke:
Have you ohmed the wires from sensors to abs module. Unplug from sensors and module, paper clip in one end, then see if you get as close to 0.00 as possible, OL or hight resistance means broken wire.
Every time you turn the key off and back on the ABS computer reboots and checks the status of the ABS sensors. As soon as I fixed the problem on my truck it reset the light in less than 100 feet.
When my front wheel bearings went out many years ago and I replaced them, mine did the same as yours. But this last time 2 years ago it did not after replacing the bearings and rear sensor. The lights just went off about 2 months later.
Should I get a scanner that can reset abs codes and see if it comes back?
You would have to be sure the scanner will read Dodge ABS codes. Many brands say the read them but not sure anyone has found one that does on our trucks. I maybe wrong lets see what others have to say.
Be a good idea, and see if you can do a live data too while driving.
Although when I scanned mine, snap on said front passenger side is dropping signal and rear sensor was functioning fine, but in codes it said rear sensor was bad. May want to try another rear sensor you could of got a bad new one. 20191114_160550.jpg.76b50479f24110fcac97529446619671.jpg
Edited by Dieselfuture
Stupid autocorrect
Most scanners won’t read 2nd gen ABS codes. Gotta spend some serious $$ for snap-on or similar.
Update:
I have some bad news... the abs light came back on...
It was fine for a week driving back and forth 2 hours a day, then i started it today and the abs light came on as i was pulling away.
Does anyone have any experience in code readers that will read abs on these trucks? My 300 dollar autel abs scanner wont do it. I really dont want to take it to the dealer again so they can spend 2 minutes reading a code for 100 dollars.
I know that the chrysler tru star scanner would for sure work, but anything in the price range for a diyer?
Not many people own a Snap On scanner. I'm one that doesn't. Love to but not for their price... Ugh...
I have a Snap On Modis that reads ABS. Bought it new a year ago because SO added ALL American to the Uk list... worth the ££ as no one here wants to mess with American diagnostics
On 3/9/2020 at 9:57 PM, Rotket said:
Update:
Where did you get the abs module repaired. Mine needs repair. Also I have heard you can still buy new module from dodge anyone know if thats true.
Module Master
https://www.google.com/search?q=module+master
2006 S Main St, Moscow, ID 83843
(208) 892-0764
Comes with 5 year warranty and all parts used are upgrades. All for $130...
https://modulemaster.com/rebuilds/shop/brakes/abs-modules/abs-kh-dodge/
Thanks module master looks good.
Another update:
Borrowed a friends 3000 dollar snap on reader. This thing was incredible, could even shut off my injectors one by one, which I didn't even think was possible on our trucks. Any who.
Reader showed that there was no signal going to the left front wheel sensor, and showed no mph reading on that wheel. Keep in mind all of the sensors are new, but i supposed it was possible that i had a bad one out of the box.
Replaced the sensor and I'm still not getting signal to it. The tone ring looks good on the new bearing, so I'm guessing that the connector going from the module to the sensor has a short in it.
I'm going to investigate more later. The nightmare continues.
ModuleMaster told me that they found its a 50/50 chance that dodge will work with aftermarket wheelhubs/sensors, they recommend only getting factory parts for this matter. Something to do with all these frequencies that don't match exactly for what dodge wants to see.
My brand new timken hubs are showing random signal loss, I thought that was my problem until I saw a code for rear sensor, weird thing about the rear sensor snap on said it was bad but it was reading better then the front and not dropping signal.
You can ohm your wires from module all the way to sensors. Unplug sensor and module sides, put paper clip in sensor side and use ohm meter on module plug and see if you get 0.00 or as close as possible to that. More resistance = loss of continuity in wiring.
Yea that's going to be the plan. Just hate disassembling everything down to the bearing for the 4th time. Its getting old
