Alternator got SMOKING HOT
- Replies 19
- Views 10.8k
Florin1 7 posts
Mopar1973Man 5 posts
JAG1 2 posts
Haggar 2 posts
Popular Days
@Florin1, could you make a couple of clarifications? Are these new batteries? Or, refurbished batteries? Before replacing the alternator, I would disconnect all battery cables an
My alternator got smokin hot and turned out to be a dead cell in one of the batteries. Be sure to load test the batteries separate as a bad cell can put the alternator into full on and cook itself try
5A fuse goes in the blue wire of the PCM. https://mopar1973man.com/subscriptions/
Hey all. I bought my truck as a theft recovery, and so all the battery wires were cut up. I replaced the wires, and also the serpentine belt this evening due to a failing damper. I fired it up and let it idle, everything looked fine, and then like 5 min of idling and I started smelling an almost burnt plastic smell. Was looking at the alternator and could see smoke, so I killed the engine. The alternator was extremely hot! It looked like some of the solder or whatever holds the copper wires together, started boiling. Looked like tar. I wasn’t sure if it was motor oil that got splashed onto the alternator. Not sure. B it the smell was definitely not oil, and it definitely stunk! The alternator didn’t make any noise either. I thought that maybe I routed the serpentine belt wrong, but I triple checked, and it’s as per the sticker on radiator support. I took tension off the belt with the idler, and spun the alt. pulled in both directions and it spun freely. And there wasn’t any play in it either. Any ideas? Thank you.
2001 Cummins 2500 4x4 5speed.
