Used Pacbrake install
- Replies 66
- Views 12.8k
Gregturley 24 posts
gimmie11s 11 posts
Mopar1973Man 6 posts
Ironforger 6 posts
Parts from Amazon finally showed up. Got it plumbed with push to connect and air brake line. Looks a little cleaner now. PARTS, PRICES, SOURCES: Exhaust housing w/vacuum cylinder: traded .40
Here is my wiring diagram for the Pacbrake using the Cummins ECM. I found the correct terminal on my 2nd try and they are cheap. $2.33 for 5 with free shipping had them in 2 days. Source and PN will b
Check out my exhaust brake article. 1st article I've ever done (and redone after Mike's input). I tried to cover everything and give a few different ways to wire it up. Rebuilding an exhaust brake
Bits and pieces of this are in 2 different places here so i decided to start a new thread on this. I'll list all prices and where i bought everything at the end. I'm doing this as cheap as i can, but the way i think will be most problem free. If you see something i did wrong or need to change let me know.
I started with a used exhaust flange and vacuum cylinder. Took a few days to get the butterfly free and cleaned up but its working now. I had to buy a vacuum solenoid and i am using push to connect fittings and line for most of it. Reason for this is if i have to change to an air cylinder i wont have to change my plumbing.
Amazon should have the rest of my parts here by Sunday so until then I'll figure out mounting locations and build the wiring harness.
