W-T ground wire mod - Popping 150A circuit breaker
- Replies 14
- Views 2.7k
Mopar1973Man 6 posts
Dieselfuture 3 posts
LorenS 2 posts
01cummins4ever 1 post
Popular Days
In the this case the cam sensor got replace that stopped the P0341 code. Then the grid heaters remain unplugged for now and still the circuit breaker is holding. My new one is here on my desk waiting
No. There is literally nothing to see. It's all by feel. No way to even make a video with my big paws in the road. You can't even see the sensor from the top.
Yep been their done that one, a 1/4 drive ratchet with a couple flimsy extensions for flexing
Ok.
I did the ground wire mod for my landlord Cummins Truck. He had a bad alternator (Bosch) which was crossing the 60mV line with AC noise. After the the mod it dropped to 10 to 12mV AC. Typically it does make a huge improvement.
Next day it pops the breaker. I assumed the diodes are bad enough to blow the breaker from shorting diode. Changed to a brand NEW Denso alternator.
Drove the truck to my house and the alternator was hot and pop the 150A breaker again. At this point its my breaker from my truck in place and it popped again which my truck has never popped the breaker.
Found out a sticking grid heater relay could produce a enough current draw at 95A to overheat the intake horn (clue) which melted the back of the vacuum valve for his exhaust brake. So I unhooked the grid heaters from the drive side battery problem stopped. The other clue was the truck ran the batteries dead a few times which is weird to have him complain about dead batteries? Now with the grid heater out of the loop seems like the problem is resolved pointing out the grids heater have possibly been sticking. Remember boys and girls grid heaters on post heat do NOT light any thing on the dash showing the grid heaters are running other than the batter voltage is typically low. In this case the volt gauge would hang low for several minutes before popping back up.
