@Mopar1973Man @Me78569 @Quadzilla Marco @Quadzilla Power Replaced both fenders this weekend so i had a lot of crap pulled loose.
  Quad set on default tune level 3. This morning on interstate truck wont go over 2000 rpm, wont build over 8 psi boost, feels like a complete dog. Power level bar was green then turned red after warm-up. Noticed power level bar go yellow a couple times while driving. Switched to power level 0 and truck drove normal. Checked all settings, changed tunes, switched back to default and still is a pig.
 Can't data log with my tablet. Couldn't get quad to connect to my phone to data log.
 Any ideas on what i screwed up?
Edited by Gregturley
  • Replies 7
  • Views 1.1k
Greg,
Sorry I have no insight for you....  I hope someone will chime in.  I need to replace fenders on mine, so I want to see what you find.  It will help me not make the same boo boo.  But it sure sounds like something didn't get plugged in just right or you missed a ground....
Hag
your sure you are on level 3?
What are your backdowns / defuels set to ?  the yellow bar happens when a backdown is triggered.
Have you run throught the install directions to verify you have it connected correctly still?
Yes, this time I'm sure of the level. Grounds and power got pulled but nothing else was unplugged. Just moved it out of the way. I'll check again on the settings. Thank you
Turns out i messed up my waste gate actuator. Not sure what i did or it was just bad timing but for now waste gate is tied shut. Didn't notice the low boost at first i guess cause i baby it till I'm on interstate in the morning. Low boost, high egt, Quad caught it, i did not. Guess there's not much point in having $1000 worth of gauges if I'm too asleep or retarded to look at them. At least no damage done and a free fix.
Mine been like that for few years, good tune and shouldn't really need it.
I really dont need it now so I'm leaving it alone for now.
