Fass 165 install help
Hey guys began installing a fass TS 165 on my 01 tonight. Just wondering where I hook my wiring harness to start my lift pump. My instructions say hook green and red to battery terminals (did that) then says plug into the oem lift pump harness but my only other connector on the fass harness is a small red wire with a fuse tap. Can I solder this red wire into my oem lift pump harness or do I need to use the add a fuse? Other then hooking up this wire my install is done just waiting till daylight in the morning to finish up. Thanks
  • Replies 29
  • Views 22.5k
  • Yes that will work. The trigger wire is the yellow with white tracer that was used to power the factory lift pump. That goes to terminal #86.  Red power wire to terminal #30. Green grou
  • I don't think you can get those connectors separately.  You can make your own connection using insulated male and female spade  connectors like I did below.
  • Royal Squire
    Royal Squire
    I bet @Me78569can tell you where to get a plug like that
Sorry to bring up an old thread, but I’m installing a FASS 165 and wondering if anyone knows the part number for this plug...
that looks to me very much like a Deutsch DT series 2 pin plug, can't really tell until it's unplugged, if there are green wedges down in the plug securing the terminals then it is, sometimes the wedges are orange if a copy
Caterpillar do those so if you know anyone that runs Cat equipment or repairs Cat stuff they will have those  OR a Cat dealer..... ours  in the UK is Finning, Texas is Holt
If it isn't a Deutsch just get a male and female chop old off and fit both as they really are everywhere, the deutsch terminals do need special crimps  though, the link below is a copy as the wedges are orangehttps://uk.rs-online.com/web/p/automotive-connectors/1878741/?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Connectors_Whoop-_-Automotive+Connectors_Whoop+(2)-_-1878741&matchtype=&aud-827186183686:pla-333299766620&gclid=Cj0KCQjwo-aCBhC-ARIsAAkNQiuCzncJN0k9or7-LuQgOmXxso0criiw5IE37e6_3Dbp20COxRGzMjgaApr7EALw_wcB&gclsrc=aw.ds
Here in the UK terminals are seperate, I buy them by the 100 and always the gold coated ones, they are coated with gold as it's a soft metal so when the plug is connected the male and female terminals make a better connection due to all the microscopic imperfections being smoothed out
Edited by wil440
It seems one of the pics tmaxxs10 posted shows the part number of the plug.  I just didn’t zoom in enough to see it with my phone.   On my iPad it was easy to see.
Thanks to everyone for replying!
Tom
that is the part number for the black outer casing,  Just search for Deutsch DT series 2 pin plug
This kit should do the trick shouldn’t it?   Even if the female plug doesn’t mate with the OE plug I can lop it off pretty quick like you suggested and slap the new male plug on.   Not sure of the OE wire size however.  This Kit is good for 14-16 gauge wire.
Edited by Tambs
Forgot the pic
yes that's what you need, now the crimps like I said are special,   look at the terminals in your picture, you'll see one end of both male and female have a green band , this is the crimp end, you remove insulation so that the wire is bottomed in the terminal and the insulation is just at the tip of the terminal, the crimps have 4 small anvils for want of a better word that move inwards to put 4 indentations in the crimp area, this keeps the terminal round so the wedge holds it, just do a search for Deutsch crimps.
I replace any terminals that are bad with these, and don't forget they are reusable and sealed
Deutsch DT are good stuff, most of the oem plugs are Deutsch of some kind.
