- Replies 8
- Views 2.8k
Popular Days
Are on concrete while turning the wheels? If so the drive line will bind since the wheels are not turning the same speed.
If this is happening on asphalt or concrete, what you are talking about could be quite normal. The front axle shafts do not have constant velocity u-joints (CV joints). Consequently, when the steeri
Just when you think your done- another issue.
I have an situation where when in 4wd the truck functions fine (mostly to pull my boat out of the water at the lake) no issues.
The problem is that if I turn either left or right while in 4wd the front end shudders pretty violently. When I straighten back up its fine.
I got the truck off the ground and ran it in 2wd and 4wd with the wheel straight ahead. All worked fine until in 4wd if I turned the wheel either right or left the front end began to shake as if something was out of balance but in a big way. I straighten back out and all is well.
Seems like something is majorly wrong here. The front differential fluid is up tp the fill hole and nothing seems loose or broken. It goes in and out of 4wd easily with no issue.
If anyone has any ideas or has had this happen to them I would truly appreciate and help.
Thanks Neal
My truck details again:
2001 Dodge 3500 5.9 Diesel 4x4 Dually
Automatic Transmission
All Stock NO Mods 82,000mi
