Sealing Vent Hatches on the RV Roof
- Replies 35
- Views 7.3k
JAG1 11 posts
dripley 6 posts
IBMobile 5 posts
Mopar1973Man 3 posts
It took us about 10 days, not full time, but the last 3-4 days was was the hardest. JAG1 came through with his carpentry skills on patching a few holes; the removal of the skylight over the shower a
I am just happy that @IBMobile didn't have to drive all the way home with you stuck to the roof.
I'm picturing this
It's that time again for me to reseal the vent hatches for the 3rd time. Had the RV new since Sept. of 03 so not too bad. One thing I've discovered is it is easier to reseal by placing blue masking tape in a square around each vent and spread the self leveling Dicor Sealant with a brush. By doing this you are working it into the voids, around each screw and working it into the surface for better adhesion. This also smooths it out for the next time you want to reseal because with an even surface it's easier to wire brush the surface (by hand is important) exposing a nice clean surface for the new coat. The wire brush will take off anything loose, but you need to be extra careful not to hit the rubber roof. I think double masking before the wire brushing will help.
Hope this helps as I think working sealant into the surface is better than laying tape or caulk.
