Hey everyone.
I’m new here. Have always read Info on here but just joined. I bought a 99 2500 2wd to flip. It started as a side job a guy wanted a vp44 installed because he thought that was what was going on. Long story short put in pump and no start. Guy was over it and I bought the truck for cost of the pump. Talked to blue chip diesel and did there diagnostic test and lead to the ecm. Sent the ecm off and got it back. Still no start.
  • Replies 15
  • Views 5.4k
  • Ironforger
    Ironforger
    Amazing fix!  Good job. Can't help wonder if it was not necessary to replace the VP44 and rebuild the ect.   Years ago I bought my 99 beetle tdi  with 100k miles on it dirt cheap because the
  • Loveacummins
    Loveacummins
    For anyone curious. I came across something that wasn’t even on a Cummins forum. It was on a gas 1500 dodge forum that said if the door lock fuse is blown the truck will have a crank but no start prob
  • hdpwipmonkey
    hdpwipmonkey
    This is interesting...   I am going to go pull my fuse and see if she starts  Switch... Hell, just pull the fuse and put it your pocket and take it with you
Any trouble codes pointing to the VP or the ECM? Fuel system bled properly after the VP install?
5 hours ago, Loveacummins said:
Hey everyone.
have fuel at the injectors. The truck will run with the pump hard wired on pins. When I got it the truck had sat weeks with the batteries disconnected. No codes were present at the time. Sent the ecm in after talking to blue chip diesel.
Who did your ECM? A lot of fly by nighters out there.
Edited by dripley
Does the WTS light come on as soon as you turn the key on?
The wait to start light does come on. That is one of the repairs they did. Computer specialist did the ecm. It was one of the top 5 on a thread I was read somewhere on here.
Maybe check the wiring between the ECM and VP.  If it runs while hotwired and the ECM is functioning as it should be then maybe you got a bad wire between them.
definently going to start chasing down wires. The truck is very clean under the hood. I’ll post when I have done more. Thanks to everyone so far.
For anyone curious. I came across something that wasn’t even on a Cummins forum. It was on a gas 1500 dodge forum that said if the door lock fuse is blown the truck will have a crank but no start problem. Well. Being that it was a Chrysler truck I figured it couldn’t hurt to check. Noticed the remote didn’t unlock the doors so I tried with the door switch and nothing. So went to the fuse box and found the lock fuse and it was indeed blown. Replaced and truck fired right up. I feel this was ridiculous but the stuff I read said that some ecm signal travels through that circuit. Thanks all until next time.
That is screwed up, I hope my truck is not like that :pray:. Or if it is, it be a good one to put on a switch so no one can steal it if you're parking out in middle of nowhere.
I am going to go pull my fuse and see if she starts :bolt:
Switch... Hell, just pull the fuse and put it your pocket and take it with you :lol:
Years ago I bought my 99 beetle tdi  with 100k miles on it dirt cheap because the previous owner couldn't figure out why it wouldn't run (started then died right away). He took it to a dealer who charged him $3500 for a new turbo and injection pump which did not solve the problem.
I didn't know what I was getting into when I bought it but I took a chance. After a couple of days me and a friend figured out issue was due to a faulty N75 valve. It's a $35 part which controls the turbo boost valve.
I drove that car for 10 years and put 235k miles on it until I blew the head gasket. Now she sits on the side of my house waiting for me to find time to fix it!
Wow! I would have never guessed this. I am glad my truck is factory a base model truck now:lmao:
  • 3 weeks later...
Everyone pull your door lock fuse and see if the truck runs. That's the craziest thing I've heard but chasing sparks around will drive you nuts at times.
Depending on what Central Timer Module you have, by pulling fuse 13 you have pulled the constant hot to the CTM.....  if it doesn't start, it is because the CTM thinks the truck is being stolen.
HTH
Hag
I have pulled this fuse in the past when my door key lock got wet and was shorting out. It was sending unlock signals constantly making my locks click.
Pulling the fuse on my truck caused the engine to start and then shut off 1 second later. This fuse sent power to my factory alarm and it would trigger the immobilizer without the power.
