Looking for Staff Members
I recently purchased an 01 regular cab 6speed 4x4 Cummins. The front measures approximately 4” lower than the rear. Is this normal? I don’t have the extra blocks and spring that I believe is the camper special? I just have 3 leafs, with 1 overload underneath, and a 4-3/4 block under the leaf pack. Is 4” a factory amount of rake in these trucks? Are my front coils just warn out? I’m measuring 25-25.5 in front and 29-29.5 in rear. I do have a slightly heavier front bumper. I was going to add a coil spacer to get it closer to level but that will still leave me 1.5-2” low in the front. Which isn’t bad but I want to make sure my coils aren’t warn. What are you stock measurements if you have any? Thanks for any help!
Wanted to ad it’s a 2500, and I measured from the center of the wheel to the fender on front and back.
  • Replies 44
  • Views 5.3k
  • Royal Squire
    Royal Squire
    Hook a trailer on and it will level right up
    Not true.   I'm completely factory height, no lifts, had my front axle aligned back at 350k with my first set of tie rods. My truck has always had good lane holding. Hold center extremely we
  • Yep never do another a wild hair thing like that again. It was expensive and it wasn't right. I'd rather get a raise from my work any day
2 hours ago, 01superb said:
Here’s mine. I’m not sure where you measured exactly. But I’m between 13-14” depending on where you measured. spacer.pngspacer.png
I just did a quick measure from the ground to the underside of the fender wells. Nothing that accurate.
11 hours ago, 01superb said:
4” just seems excessive. I can’t stand it with that much of a difference. I’m going to put a leveling kit on it which should close the difference to 1.5-2” instead of 4”. My truck looks like a sled pulling truck lol spacer.png
Thats a nice looking truck the way sits for my taste anyway.
Pictures don’t show it as bad as it is. I don’t mind a little rake but it’s excessive.
I like mine at 3", Not sure if 4" would bother me either. I used to deliver building materials looooonngggg ago. Every 3/4 ton I drove had a lot of rake to them empty. Always liked it.
2 minutes ago, Doubletrouble said:
 Hard to see much take in the pic I think. Doesn't look to bad to me, not my truck though. May look different from a different angle
I am not a big tire guy myself but like how some of them look. The cool thing is we all own our trucks and can do any darn thing we like to them. My daughter dated a guy a while back. They came over in his brand new F250 all jacked on big tires and a lift so tall I could hardly see over the grill into the engine bay, and I am 6'4".
 My last truck (1995 GMC Z71) was lifted slightly. 3" suspension and a 3" body lift to clear the 33x12.5x15 tires I had for it. It was fun but the GM's start out so short anyway my dodge 3500 actually sits just as high as the GMC did. The GMC was very hard on steering and suspension parts. With the dodge I'm more concerned about it being reliable and longevity. I will leave it at the stock hight and run stock size tires on her.
Also need adjustable track bar, longer end links, longer shock absorbers and a realignment. Then when you load up the RV or whatever you'll hate the rear end sag. So next is the air bags, which need at least 10 psi all the time to not damage them. What a pain in the neck. The most I would ever do is a 1 inch level kit because when you measure the 2 inch lift kit, once installed, it's really more like 2 and a half inches lift kit. So one inch is the most you should do. Your right I'm no expert on the subject, but I know and experienced all I ever need to know
I'm sorry to be so stubborn as a mule on this. Someone may have a picture to post :thumb1:
This is with 6k on the rear axle. I do have the overloads hence the level ride.
Here is a picture of my '01 empty and loaded. It weighs 7800 lbs with all my junk. I haul commercial, sometimes heavy, so rather than airbags I spaced up my overloads to make contact sooner.
The factory rake is important if you haul/tow.
My truck measures 4” difference. If I do the front 2” level and it changes 2.5” then I still have a 1.5” rake. I’d be happy with that.
The whole thing behind the rake is so you can carry a load without your headlight shining in the sky because its swatting in the rear. Any leveling kit you put on the the rear will sag down when loaded. I've been up close to the 26,000 pound limit on my registration of my plates.
Here I am with GCW of ~17,300 pounds, and about 62 foot long total. Sitting level. (Nevada 2020)
Another... My truck is always level towing. No need for lift in the front.
Level hauling 2 cords of firewood...
Another hauling hay... Five 1-ton bails that's 10,000 pounds just in hay on a bumper pull car trailer.
12 hours ago, Doubletrouble said:
 Not to go off topic but, nice 5'er dripley
Notmso much so since the tree fell on it.
Without the extra overload if you do load up heavy the rear will be squatted.
Dont let us beat you up to hard on leveling. If its what you want do it. Just do it right so you dont have regrets down the road.
Exactly! :thumbup2:
:thumb1: what he said. Lift it, level it, it's your truck, do it the way you want. Just do it safely.
 Like @Mopar1973Man explained earlier, make sure what ever you do that your alignment is correct to maintain the safety factor. When you do change things let us know what ya did and we like pics. Before and after maybe?
Please do... Articles really do help a bunch of folk to just read what it took to make the upgrade or project...
6 hours ago, Doubletrouble said:
I need a trailer like that royal squire.
Borrowed trailer from my neighbor
