- Replies 13
- Views 3.4k
Royal Squire 4 posts
Mopar1973Man 2 posts
Haggar 2 posts
Dieselfuture 2 posts
Took the first flasher back to oreillys and told them I thought it was faulty and they exchanged it. Turn signals are now working. 😎
The multifunction switch is usually the culprit for intermittent problems. It is not hard to do, you just need to have some of the "tamper proof" torx bits. (the one with the hole in the middle.)
If the turn signals are not working but the 4 way (hazard) lights are then it's most likely the multifunction switch has gone bad.
Turn signals on my 2000 not working and seems to be intermittent according to my wife. I haven’t looked at it yet. Emergency flashers still work. Any thoughts?
