Dash brake light randomly illuminates
- Replies 20
- Views 4.6k
BennyGGG 6 posts
dripley 4 posts
Doubletrouble 4 posts
Mopar1973Man 3 posts
Switching to led bulbs would help to reduce amp draw on wires.
Since it messes with the cruise control I would think its on the brake pedal, like in the switch. That will disable the cruise. I dont know a good way to test that though. If you remove it you have to
@Mopar1973Man sells LED replacements in the forum store if you want to go that route. (Just a little free advert for ya mike!)
Dash brake light randomly illuminates. Sometimes it stays on from start up and will turn off within 10-15 min of driving. Other times it comes on and off while driving.
It’s not the parking brake. That appears to be working properly. When the parking brake is engaged the dash light comes on. If I start to drive it will flash. When I release the parking brake it extinguishes.
Brake fluid looks good. Upgraded to 3rd Gen brakes up front and did a full brake job 4 months ago. Had no issues until now. Only recent maintenance is new tires. They are 34s.
this issue also seems to cause cruise control to not work.
possible speed sensor issue? I’ll double check tire pressure tomorrow. None of them look low.
any advice is much appreciated
