Weird Electric issues
- Replies 12
- Views 6.6k
Mopar1973Man 4 posts
JAG1 2 posts
01_Cummins_4x4 2 posts
Doubletrouble 2 posts
I was amazed by how many issues a bad ground and poor wiring caused with my chevy. Opposite side flashing, or not at all, reverse lights lighting up when hitting the brakes, lights going dim when hitt
Please remind me to buy a brand new second generation Dodge again when the time comes and I am too old to remember.
Weird. The only other thing I can think of, is if someone had re-pinned the wiring connector (highly unlikely), but it could be a wiring issue between the TIPM and the steering column.
I've got a 2006 Dodge ram here with some very strange issues electrically. All stems around the headlights and turn signals and the multi-function switch. If you turn the right turn on it actually does light the right turn signal. Now turn on the left and the right is flashing. Turn on the hazards and only the right is flashing. Now turn on the head light there is zero headlight but markers and fog lamps. Try hi or lo beam it will flash for a brief moment but turn on the wipers and spray the windshield. Can't get hi wipers at all only lo. Now what did I do so far...
Its like the CANBus is getting the wrong message from the multi-function switch. There is only 5 wires coming and going to the mult-function switch. I did find someone badly made headlight bypass relay. Pull all that and return to the factory wiring and got headlights for a short time only on HI beams only. by the time I pull the column apart twice I lost the heads a second time. The owner has brand new LED headlight bulbs which I've seen but hi and lo beam work. Still might get a quick flash when you pull the stalk back but wiper and spray come on. No I did accidently roll the wiper knob on or push the end of the knob in for spray.
Make matter worse I've still got his other 2002 Dodge here waiting for a injection pump to come back from the rebuilder. He's got zero vehicle running now. Any info to help out here would be welcomed.
