- Replies 16
- Views 6.5k
Mopar1973Man 5 posts
Tractorman 3 posts
That Guy 3 posts
Doubletrouble 2 posts
You are experiencing an unusual symptom. I am assuming that you have a manual selector for the transfer case. To simplify troubleshooting, I would disconnect both vacuum lines from the CAD. Select
Take your mouse on hover over the dotted underlined words and the web software will display the meaning of CAD. I've added a ton load of acronyms to the websites database just
Pulling a trailer through the pasture the other day and hit a muddy spot. started slipping so I put it in 4Hi, 4x4 light came on after a foot or two. Rocked tried for a minute or 2, both directions and no luck. Moved back and forth about 10 feet, spinning. Put it in 4Lo and the truck pulled right through with no issue.
Coming back around a bit later with the same trailer I experimented a bit. In 4Hi, the front wheels were not getting power. Played around a bit, nothing. Truck would come to a stop if I turned the wheel, rears spinning away, fronts doing nothing. 4Lo, same as before, pulled right out no issue. Fronts getting power and spinning even turned.
Should I be looking at the transfer case, vacuum shift, or the axle? I did have the axle shafts out and had to reinstall the vacuum disconnector. Since it works fine in 4Lo, I'm leaning towards the transfer case, but I have no idea what to check.
