High idle
Hey guys. I’m trying to get high idle going in my 2000 5.9. I have the moparman switch but I have to get it enabled. I took it to the dealership to get it done and $180 later it didn’t work. I’m from Canada so I can’t rent an s03 from dap. Any of you guys in Canada have an s03 you’re willing to rent to me or even you guys in the US?  Or have a software number I can tell the dealer to install ? Thanks in advance, I’m in quite the Perdicament here
  • Replies 33
  • Views 6.7k
    Yes. I've got one left let me correct the store... POOF! (Magic dust every where). One sitting on my desk.
  • Royal Squire
    Royal Squire
    @Me78569That is what I did but they still had to look it up.
  • If the outside air temp is less than 32* F and your coolant temp is less than 170* it should activate.  There's no way a block heater will get your coolant to 170*.   Mark
So was the flash not done correctly, or any ideas why my truck does not want to idle up/3 cyl idle. I've replace the inlet air sensor, and I can guaranty the coolant is below 0 f.
Mark
2 hours ago, gipperkid said:
Any High idle switches in production?
I’m not too sure why but even when my block heater is plugged in all night my 6 cyl high idle still activates. Does this happen to you guys?
Mark
Yes it could...
Even though the block heat might make 90 to 100*F temp b ut blowing outside air can upll that down. Then when you start the activation of the high idle 6 CYL just needs.
  • Coolant below 140*F
  • IAT below +32*F with grid heater running.
3 CYL...
  • IAT below +15*F with grid heaters running.
My problem is the up idle has never worked since I've owned the truck, had it reflashed 10 years ago, and still nothing. Kinda sucks up here in NW Minnesota when it idles alot when it's -20 to -30.
There is no controls for high idle. It must meet the sensors requirements. The is no steering wheel control like 3rd gens. Hence why the high switch was made to give control over it.
Understood, what I am saying is at 0* F and below, this truck has never idled up or gone to 3cyl idle even after it was flashed. Hell, I didn't even know it is supposed to do that until I started following this form years ago.:shrug:
Mark
Mark
They must not have flashed it the right way, some call it high idle some call it winter idle, I heard other names for it that I can't remember.
Mark
ONLY if the high idle software is enabled. Once enabled it will be rather random hit miss. Be8ng based on IAT to start. Then if you had my switch then you can command what you want.
