need help deciding on a turbo
- Replies 61
- Views 17.3k
Silverwolf2691 15 posts
dieselautopower 12 posts
LorenS 10 posts
dripley 7 posts
Thanks for sharing, nutin gets the blood pumping like the starting line of a sled pull! My 1975 F-250 gasser, 6500# stock class. Missing my old sled puller and smelling the 110
Its Christmas in February.
I just got my HE351W (not the HE51CW) in the mail today! @dripley should be getting his, too. BlueOx01 was the first to install this turbo, that I know of. Here is a link where this turbo is discus
I've had blue smoke coming out of my exhaust upon acceleration, after idling for an extended period of time, for a while now and it smells like oil burning, since I think blue smoke can also be excess fuel. Since oil can only enter the exhaust via the turbo oil seals and the valve seals, I think its the turbo because around 2017 (I think) I had my cylinder head rebuilt due to my head gasket leaking coolant down the side of the block. I haven't pulled the down pipe to confirm yet but its on the list for it.
I'm getting into sled pulling with the truck so i was wondering if it would be more beneficial to upgrade the turbo since it would have to come out anyway. I'm only pulling in a workstock/2.5 class in Southern New England so wringing every last horsepower and torque out of it isn't needed. I'm also still trying to be able to drive the truck daily if needed.
i had a few options that i was looking at but i would like a bit more guidance.
https://www.dieselautopower.com/dap-screaming-eagle-sxe-fmw-2nd-gen-fit-62-68-12-t3-gated-hx40
first option
other possibility was a 62/65/12 from DAP..
https://powerdrivendiesel.com/product/power-driven-diesel-hx35-turbo-kit/
http://turbolabofamerica.com/category/holset-turbo-upgrade/
PDD seems to have found what turbo lab was doing, and copied them. not gonna go bigger than 62mm inlet.
if i go this route, i would probably go through turbo lab due to price.
https://powerdrivendiesel.com/product/power-driven-diesel-hx-super-9-turbo-kit-bundle/
this seems to be an HX35 with an HE351CW exhaust housing, and an HX40 flange grafted on.
I guess I'm just wondering if upgrading the hx35 is worth the cost savings or if going to an SX-E is worth the flow/efficiency upgrade.
From lurking for a while I've seen that mopar1973man is pleased with his HX35/40 hybrid, that's what's making me question keeping/upgrading the hx35..
Thanks in advance
Silverwolf
