Rear Differential Chatter
- Replies 11
- Views 2.6k
JAG1 4 posts
IBMobile 2 posts
Dieselfuture 2 posts
Joe_Pool 1 post
Popular Days
I've seen @JAG1party. By 9PM you can stick a fork in him; his done.
As an alternative to the dealer, I use Sta-Lube EQUA-TORQUE differential friction modifier made by CRC. It meets GM#1052358, Ford #M2C118-A and Chrysler #4318060. It comes in a 4 oz tube and is enou
Next comes the beer, next the chit chat and a full blown party, then more show up from all over. Nothin' ever gets done.
My limited slip chatters a little bit in the turns. How much additive do I add? I changed the gear oil about 10K miles ago with Dino gear oil that had some friction modifier for limited slip. Chatter just started. Should I go 4 oz. and add more if needed?
Thanks
