Rear Differential Chatter
My limited slip chatters a little bit in the turns. How much additive do I add? I changed the gear oil about 10K miles ago with Dino gear oil that had some friction modifier for limited slip. Chatter just started. Should I go 4 oz. and add more if needed?
Thanks
  • Replies 11
  • Views 2.4k
  • I've seen @JAG1party.  By 9PM you can stick a fork in him; his done.
  • As an alternative to the dealer, I use Sta-Lube EQUA-TORQUE differential friction modifier made by CRC.  It meets GM#1052358, Ford #M2C118-A and Chrysler #4318060.  It comes in a 4 oz tube and is enou
  • Next comes the beer, next the chit chat and a full blown party, then more show up from all over. Nothin' ever gets done.
Yes, a 4oz bottle should do it.
4 hours ago, Dieselfuture said:
:popcorn:
Don't get your hopes up around here DiselFuture. We just 'Restful Ranch' at the end of the trail.
:USflag:
As an alternative to the dealer, I use Sta-Lube EQUA-TORQUE differential friction modifier made by CRC.  It meets GM#1052358, Ford #M2C118-A and Chrysler #4318060.  It comes in a 4 oz tube and is enough for most diffs.
:USflag:
What,... I just wanted some popcorn, that's all
Next comes the beer, next the chit chat and a full blown party, then more show up from all over. Nothin' ever gets done. :thumb1:
Dont stop I am half way there. :popcorn:
Then we will party maybe a bit of street racing. It's all good...
