- Replies 17
- Views 5.9k
Zamboni 7 posts
Tractorman 3 posts
Dieselfuture 2 posts
ddmk6 1 post
Popular Days
I have a HX35 turbo and an 800 RPM stall convertor with no problems backing an 8K 5th wheel up a steep driveway into my backyard. The rear transmission band may be slipping. Put the transmis
After doing a bit more reading, the HY35 turbo may spool better in that dead zone just because it has a smaller exhaust housing. However, exhaust gas temperatures may run hotter under higher rpm load
So the issue I'm having is i have no power in reverse, not transmission problem power but my truck will not push my 5th wheel trailer in reverse up an incline, just black smoke. So ever since i changed to an HX35 turbo and a lower stall torque converter this has been an issue. My thinking on this problem is the lower stall converter is not allowing the engine to increase in rpm to get any boost from the turbo. So question is, will my old hy35 spool better with this setup or would a stock or higher stall converter be a better option or am i just missing something?
