Rino lining or line x rocker panels and outside lip of wheel wells
- Replies 11
- Views 2.8k
Mopar1973Man 3 posts
Dieselfuture 2 posts
Turbo Terry 2 posts
JAG1 1 post
@Mopar1973Man, I hope the 2002 doesn't get jealous of you spending so much time with Thor.. As for the topic at hand, @Turbo Terry, what is your intent with doing the bedlined wheel wells
For whatever reason, it keeps flipping the picture upside down, but oh well I did mine about 8 years ago, line x, with the protective uv coating. It's held up well for the most part, but the prep
Why not just spray some type of badliner on bottom of the truck, I ended up doing that after changing cab corners and some rockers. Just used cheaper stuff in a can easy to touch up when need to. I re
Has anybody done this. How did work out would you do it again etc Did eliminated the need for wheel well flaps etc
