Looking for Staff Members
My brother has a 2012 range rover 6 cylinder V6 diesel, he did about 6 hours work with me last night servicing and repairs to  a Cat 950H on a site I look after in return for me doing a fault on a range rover POS
Fault is low boost code P1247 turns out the intake manifold right hand side (plastic FFS)  is cracked, believe it or not it is also the cam cover, it has took 8 hrs to get the cover off, no access to anything at all, brother tells me IF the 2 turbos (1 each side) need replacing it's £5K to take the body off to get to them and after looking this is the way to do turbos on this junk.
I have been a  proper UK apprentiship trained diesel mechanic for 43 years and the idiots that designed rubbish this should be shot, just utter mechanical garbage, I have never in my life seen so many sensors in such a small space.
here's one, a bolt screws into a bracket holding lines  the head is 1/4" from the bulkhead right under the scuttle panel where the wipers poke through, screws in from the BACK, bolt is 1" long and it pokes through the bracket and stops the whole intake/cam cover from coming up and off, if it's undone it never comes out far enough to just lift off the cover, might just stove a hole in the bulkhead to put the new piece back on.
here's a tip from the UK...... DO NOT ever buy any Range Rover newer than mid 90's cos boy are they dog s### and if you come across one with the driver thinking he's the dogs just laugh and smile cos they are really a joke
Trying to get my brother into a  2nd gen ram but I'm struggling with it as he's clown
  • Replies 42
  • Views 34.8k
  • Do it, just drill the hole or punch it through the firewall (bulkhead).   In the late 70's and early 80's The camshaft lobs and rocker arms were going flat in the Volvo B27 V-6 engine due to lack of o
  • All of these new cars are a POS to work on.   Every thing crammed into a small engine compartment where you have to take four things off to get to the problem or like the Ford trucks where you have to
    I've got a gent just down the road from me wants $25,000 for his 2nd gen. Between the brand new flatbed, and other new items I can see why.
"going to be a fine line on when my 24v gets sold before it is no longer drivable on our roads I need to judge max price before worthless"
Dont let a scrap yard end up with it.
5.9's Going for big $$ on farm/industrial applications?
5 hours ago, wil440 said:
my truck isn't allowed into certain cities without a penalty, London is one, Birmingham also and growing fast, Nottingham, Derby, petrol/gas to you guys isn't affected as yet, Gas (our gas/propane) no restrictions yet and 1/2 the cost of petrol, going to be a fine line on when my 24v gets sold before it is no longer drivable on our roads I need to judge max price before worthless
So no diesels in bigger cities? If true, what is their reasoning? :shrug:
Just for fun... it may help if you have a small label on the exhaust tip, 'kills Corona'!
I remember not long ago I was saying diesel day's are numbered, and had a few that were so sure it won't be in their life time. Well I've seen the writing on the wall a while ago and believe these bastards are moving forward at exponential rate to push their bs on us. Time will tell but I'm afraid it's running short. :2cents:
Right now you have to pay a charge to enter the city, unless the car is low emissions. people who live in the clean air areas pay every day or change their car. It is getting worse and fast. Sure I read that the UK is banning  sales of new petrol and diesel vehicles maybe by 2025. Also banning the sale of LPG gas boilers for homes in 2025 too
Way more on it's way I'm sure and the only consequences of less vehicles using petrol and diesel is higher prices for fuel so you end up priced off the road. Our fuel just got a bigger % of bio too
Wow, they going overboard. What are people to do when electricity prices goes crazy with not enough to go around?
You know throughout history long term droughts and famine happened when folks turned from God. Has happened many times in the past and the rains and the healing came back when folks returned to our loving God and renewing their faith and treated each other as He commands. We are seeing an epic drought in the west with the worse possible fire conditions developing. I hope everyone knows and learns how to pray because America needs to water their faith again, stop all the contention and aggression toward one another.
It won't ever go for scrap, I'd rather build a man cave/bar out of 2 shipping containers and use it as a table
They say here we'll never power the amount of electric vehicles we need as the grid just isn't up to it
On the subject of foreign rubbish
Yesterday I had a phone call from my son, Peugeot Boxer 3.5t tipper he's a landscaper/builder, thing in limp mode, got it back here and dropped the Modis on it, Injector number 5 (DPF injector) relay think the code was PB15E..... all the info I could find was as per usual vague and obviously written by people that don't have a clue.
Found one piece that said to check fuses in the engine bay fuse box, guess what..... the fuse box lid DOES NOT come off until the passenger side headlight is removed and you can't get that off unto 2 peices of plastic trim are removed which is held on by clips that you cannot see or get to.
Now you might say that thats modern vehicles for you....  but France  where this thing was made has a law that you have to carry spare fuses and relays in the car at all times therefore you would presume that the police are hot as mustard on electrical stuff not working, not much point really if you can't get the lid off of the stupid fuse box.
No fuses blown for the injector vapourizer heater, all relays checked ok, thing is there is no  ID on the fuse box lids (there are 3) to tell you what fuse does what.
One fuse box is in the B pillar R/H/S just to the rear of the driver, they decided to mount the hand brake lever there instead of in the middle of the seast where every other vehicle here has it, the lever is 1/2" from the front of the fuse box so that lid needs Houdini to remove it and to top it off when you get out of the thing this lever catches the seam of your back trouser pocket and tries to face plant you into the tarmac, I really do hate this vehicle
Just consider every jet flying in the ski produces more CO2 than any diesel vehicle. Heck a good forest fire creates more CO2 in one hour than my diesel truck will in its life time. Just DemonRats throwing global warming at all of us.
there is also one bigger contributor that is greater than all transport put together...... Fact.....  Methane and I'll let you guys figure out where that comes from, but hey Lets just beat on the guy in the car cos we're just the dumb stupids that can be taxed to death, can't possibly tax a farmer FFS
 Gov't cannot afford an increase in interest rates with the huge debt since they don't take in enough income to cover it so now they thinking big taxation. Then inflation running at risk due to low interest rates whittles our 401 K down. What's next? We need a smart Business Man running the show.
Building departments raised building permit fees to very expensive heights together with property tax assessments higher so now you have increased rents sending folks to the homeless camps. Gov't cannot do their job correctly, do not want to work at it. They take but, never reciprocate. convolute everything bass ackwards.
  • 5 months later...
Well my dumb brother just bought another Range Rover ah well horse to water and all that
On a sort of side note the Mayor of London Sadiq Khan  (don't ask) has just increased the clean air zone around London to this https://tfl.gov.uk/modes/driving/ultra-low-emission-zone
Just a money grab but gaining momentum here not made any better by the hobbit schoolgirl
Thanks for sharing will440 it's an interesting angle your local government came up with. What will they think of next?
''POS'' as you say must mean something pretty derogatory as you guys use that a lot when describing something you dislike. :)
That's not local government It's London government. 125miles from me and in the UK thats far enough to not worry about for now
London has changed and for the worst, anyone visiting the UK just don't bother it's really not worth it, the mayor has a agenda, I'll say no more
As for POS    you must get that    Piece   Of    S###       It amazes me how much you guys pay for Range Rovers and Land Rovers  they really are rubbish
On 6/10/2021 at 3:21 PM, IBMobile said:
Do it, just drill the hole or punch it through the firewall (bulkhead).   In the late 70's and early 80's The camshaft lobs and rocker arms were going flat in the Volvo B27 V-6 engine due to lack of oiling between them.   The easiest way to replace the cam shaft and rocker arms was to slid the shaft the rock arms road on to the firewall, mark where the shaft made contact,  drill a hole there. and finish by sliding the shaft through the hole into the passenger compartment.  Next was to slide the cam shaft to the firewall and drill another bigger hole for for it to slide through then I'd go to the other side of the engine and do the same thing there.
Yep, been there, done that.
I have heard this many times about RR/LR.
I have always said, never buy an expensive luxury car, lease them. That way you always have an out. Never ever own one out of warranty.
bang on, I lease a 2020 Volvo XC40 hybrid for my wife  you really would not want to buy it, great car but out of warranty it would be an ouch, 3 cylinder 1500cc turbo petrol with a 80hp electric motor and it just goes and fast, it has a range of about 24 miles on battery wife does about 10 miles a day when she uses it, plug it in to recharge and it sounds like R2D2 chirping and chipping away, got it for 4 years then gone
so the idea is to save the environment by not polluting yet in 4 years you got another POS :lmao:that goes into the junk pile. Good one :think:
I got a thought the other day about all the droughts and floods, that things are out of balance with the weather anyway. So this CO2 emissions that are supposed to be excessive and causing problems, could it mean that the water molecule cannot bond with hydrogen to make H2O, badly needed rain??? Mainly because the Oxygen molecule gets bonded to the carbon molecule during combustion and isn't free to become water?? I wonder if this aspect has been considered instead of the greenhouse effect that CO2 is resposible for.
Same thing here.  In California we pay the highest gas tax and fees at $1.19 per gallon and now the local county government wants to charge 4-6 cents a mile use tax and increase the sales tax 1.5% over the next 3 years to fund their mass transit.  Yes, they want us out of our vehicles.
Who's the Hobbit schoolgirl?
You should get all of your diesel buddies together, load up your truck beds with containers of tea, form a caravan through London, and dump all the containers in the River Thames. I’ve read something similar happened over here a few years ago, near Boston I believe? Seemed to work for them. As far as Rovers go, I put them in the same category as BMW, Audi, and Benz. They’re beautiful machines and have some incredible qualities, but fail miserably at being reliable. Years ago I decided to buy a car (sedan) because I was traveling so much for work. Test drove all the big body luxury sedans and ended up buying my least favorite, the Lexus LS460. The BMW 7 series crushed it in every way except 1.) reliability and 2.)ride comfort driving in a straight line on the interstate. 12 years and 142K later, nothing but oil changes, and is perfect. Also, 6 months ago Lexus replaced my interior on a good will recall that I didn’t even know about. The rep proactively reached out and offered it.
Edited by Andyba20
Greta Garbage (Thunberg)    she must have been in your news surely
was at Cop26 protesting was over in the USA last year I think..... does jack other than protesting and spouting the end is nigh but flies all over the world
We also have another bunch of nutters called extintion rebellion, these fools have been supergluing themselves to the roads in a protest to force the UK government to insulate every house in the UK for ....get this FOR  FREE....  best bit is the leader is barely able to string a sentence together  and his house is NOT insulated they have bought London and the south to a standstill even stopping people getting to hospital and causing at least one death they are now targeting cities further north
Here a Lexus is high end and being as a lot here dislike the EU right now my guess is Lexus and other none EU cars will benefit
Yes, now I know who it is.  She's no twit.  She's making a living on the Eco bandwagon.
  • 8 months later...
Well a few months ago my brother bought another Range Rover, V6 TDI, same as the last POS he had
Last week I got a call from him  "can you tow me home"  he broke down about 15 miles away
Gets there, has a quick look and right hand side intake hose is split, with oil present, wouldn't run at all
Tows him home like a conker tied to the tow bar
Turns out the right hand turbo has **it itself, he gets a pub buddy to take a look who actually is a mechanic for a independant Landrover specialist, takes a 5 minute look at it while my brother is cranking it and turns out turbo took the motor out, firing back out the r/h intake so valve damage at the very least.
To replace the turbos and the guy said if 1 is shot so is the other, the body has to come OFF !!!!  £4.5k minimum for 2 turbos and an intercooler, engine 10k plus on top
He binned it to a breakers and got 1.5k
THEN went out and bought a Porsch Cayenne, got the usual problem with the radio which does what it pleases all the time which is a common fault, calls Porsch dealer, hourly rate £268 yes PER HOUR
Some people never learn..... horse to water and all that :shrug:   I'll be towing this thing home within a year for sure
