VP44 1998.5 Eyes Burning, Bad Mileage Help
- Replies 35
- Views 6.2k
Njbenz 10 posts
Mopar1973Man 5 posts
dripley 4 posts
Silverwolf2691 4 posts
Right back to the injectors since there isn't any error codes present. Normally injectors are set between 300 and 310 bar. Most performance built injectors are 300 to 305 bar to help with flow and pin
100k to 150k you just need the change out injector they are wasted. Even though it still starts and runs fine.
Another little secret we have learned here. If you mix 128:1 ratio of 2 cycle oil and diesel fuel basically 1 ounce of 2 cycle oil to a gallon of diesel it will keep the injectors cleaner than any inj
Need some help.
I’m The second owner of the truck, 175,000 miles. All originally stock, only modifications is an air dog lift pump and a heater grid delete. When I disconnected the batteries to do the lift pump install a few months ago, I did an APPS reset using the throttle pedal.
When I start and idle the truck over the past week, I can smell what seems like unburnt diesel from the exhaust pipe. After a few minutes driving down the road and at a stoplight, before the engine is it operating temperature, I can still smell the rich diesel, and inside the cab my eyes start to burn. No codes are being thrown, no check light is on. I was pulling my boat yesterday, 6500 lbs, and it didn’t seem like it had good power going up a small grade. I am not getting any black, white, or blue smoke out of the tailpipe.
what are the possible issues that I need to check?
