- Replies 10
- Views 3.5k
Mopar1973Man 4 posts
Silverwolf2691 1 post
NIsaacs 1 post
Doubletrouble 1 post
TIPM = totally integrated power module runs everything other than the trans and engine, more or less. That's how 3rd/4th/5th gen trucks (more so on the 4th and 5th gens) can ju
Back to running. I pulled the clutch safety switch. Jumped it. Nothing. Then grabbed the test light and nothing. I went out to the fuse block (TIPM). Started testing fuses and found one blown. Changed
More to add on this... I found the ultimate cause of all this. (Be gentle ) So my exhaust brake switch is on the stick. The previous owner added a aluminum angle metal to moun
2006 Dodge - Starter issues
Just got home for lunch and now going to move the truck to get a job done. There is nothing. No click nothing. All the dash lights up. Being this is controlled by a TIPM I'm not sure at this moment what to look at next?
